8.0 USB Media Player workaround
Discussion in 'Model S: User Interface' started by ajps, Oct 2, 2016.
  1. ajps
    ajps New Member
    Chicago
    While not a perfect replacement for the existing 8.0 USB Media behavior, the following workaround might benefit many owners of large CD collections. (In our case10,000 songs.) Credit due to my girlfriend who noticed that the USB “Folder” functionality was accessing individual Artist “Folders” on our USB drive and also to “JeffB” who, in a prior post, noted that placing artist folders in alphabetical subfolders greatly improved Artist access. I have extended Jeff’s idea of alphabetized folders to a single screen with no scrolling for initial Artist access, and I have identified a simple song renaming convention that will list songs within Albums in numerical order while still preserving random and looping play. The technique can also be used to create and access playlists. The procedure outlined below is for a Mac OS X user, but the technique should work equally well with equivalent Windows tools. Entire procedure takes about 30 minutes of attended time and up to several hours of unattended processing time depending on the size of your collection.
    Step 1: If you haven’t already, format a USB drive in Windows FAT32 format. We used a 128GB SanDisk USB 3.0 memory stick.
    Step 2: Copy your iTunes folder (User>Music>iTunes>iTunes Music) to the USB drive.
    Step 3: Rename the drive to a one word label of your choosing. We labeled ours “Music.”
    Step 4: Create 9 new folders labeled ABC, DEF, GHI, JKL, MNO, PQR, STU, VWXY.
    Step 5: Drag and drop Artist folders alphabetically into the three-letter folders as appropriate. This can be done in batches by holding down the shift key and clicking a first Artist and then clicking the last Artist you want to move and dragging into the desired three letter folder.
    Note: For some users that just want quick access and who don’t care about track order they can stop here.
    Step 6: Obtain an MP3 Tag renaming app. We used the $5.99, “Music Tag Editor,” available in the Apple App Store.
    Step 7: Using “Music Tag Editor,” select all nine alphabetized folders and drag onto the “Music Tag Editor” file/folder box.
    Step 8: At the end of the “Title” tag, check the “Use File name” box.
    Step 9: At the top of the “Title” tag, check the “Apply to all” box.
    Step 10: Click the “Save All” icon in the menu bar and when the save dialog pops up check the “Overwrite files” checkbox.
    Step 11. Wait until the new Title tags have been written back to the USB drive by monitoring the progress indicator. This might take several hours depending on the size of your collection.
    Step 12: Eject USB drive, install in your Tesla, and enjoy!
    To operate: Wait for Tesla to scan drive; press USB source button; press USB drive name (ours is “Music”); press “Folders”; and you will see a single screen containing the 9 alphabetized folders. Press a folder button and select/scroll to the desired artist, then album, then song. Press the USB Source button again at any time to go back up the menu structure.
    It sounds like a lot of work, but it is actually pretty straight forward and returns much of the 7.1 functionality.
    • Informative x 3
  2. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Send this to Elon.
  3. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
    Why? Other than to show what a pain it is to get the old functionality? I'm afraid that "Elon" would think this is nifty and add it to the release notes and call the new USB behavior a finished piece of software.
    • Funny x 4
  4. Zapped
    Zapped Model S - PURE EV
    YEG <-> PSP
    How do get songs to show in the USB Favorites selection ?
  5. BertL
    BertL Active Member
    Carlsbad, CA
    Touch the heart when the track is playing, just like you do with Radio stations, etc.
  6. hmmm
    hmmm Member
    Driver Seat
    Thanks for the suggestion, good workaround.
    On a related topic, did anyone notice that we the latest 8.0 update, the "scroll back to top by default" ahem, "feature" is gone? I guess this gives me hope than 1) they are listening (pun intended) and 2) we may see additional fixes soon.
  7. Zapped
    YEG <-> PSP
    Thanks, I was making it complicated by creating a Favorites folder on the USB drive.
  8. Zapped
    YEG <-> PSP
    I just installed version 8.0 - 2.42.40 last night. Looks like the USB Alpha select column on the right side is back for the song list selection.
  9. dkonigs
    dkonigs Member
    San Jose, CA
    Unfortunately, song sorting in the "Folders" view is still broken. It still ignores the filenames and track numbers, just sorting alphabetically by song title.
    Is it that hard to just sort the files by filename?
    Why do they insist on punishing those of us who actually bother to organize our music files how we see fit?
  10. outie
    outie Active Member
    SoCal
    A better question is why can't they make something this simple work correctly? All my other cars (with mp3 playback) work correctly out of the box.
    Tesla software updates bring new features? More like bug fixes that shouldn't exist in the first place on delivery.
  11. BertL
    BertL Active Member
    Carlsbad, CA
    As a pointer, since we have so many threads on similar topics these days...
    Lots of discussion on things like Folder View, other views that don't sort correctly, other USB bugs and requirements, and some potential workarounds are in the Comprehensive USB Bug List thread. You may want to join us there.
  12. rickgt
    rickgt Enthusiast owner/member
    Carmel
    I have music in an album and separate folder that I want to play in the sequence of the album... Tesla sorts it alphabetically!! No way to go back to the correct sequence. Tried renaming files wot 01,02 in front of name... not working HELP,
  13. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Fritterer and waster of hours in an off hand wayer
    Portland, Oregon
    #13 ⚡️ELECTROMAN⚡️, Jan 25, 2017
    My albums show up in the proper track sequence. If I tap on the folder view, they come up in alphabetical order inside the folder, but If I tap on album view, then they show up in the proper track order. If that isn't working for you, then make sure there is a track value in the ID3 tag.
    I still have problems with multi-artist albums showing up properly, though. I didn't have this problem when I got the car in December, but after the first update was installed, if the album had multiple artists, it creates separate albums for each different artist.
  14. BertL
    BertL Active Member
    Carlsbad, CA
    IIRC from my former observations (have not re-checked with .114 or .22), the issue is in more recent code drops, Tesla uses filename for some sorting, but the TRACKTITLE tag for others across the interface. I suggest you try changing the name of your track by appending DISCNUMBER+TRACKNUMBER in front of both filename and TRACKTITLE to workaround the various issues, and see if that helps. It's how I have been creating my Tesla USB device the last few months to minimize some of my annoyances. More detail on all this is in my many upthread posts. Good luck.
  15. BertL
    BertL Active Member
    Carlsbad, CA
    Oops, sorry, my detailed posts are actually over in the more extensive Comprehensive USB Bug List thread.
  16. rickgt
    Carmel
    Yes, exactly the issue. Albums are broken and songs or folders alphabetically ordered.
  17. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    My albums aren't broken. "If I tap on album view, then they show up in the proper track order."
  18. rickgt
    Carmel
    Got your replies... albums that are multi-artist get separated into individual albums, hence loosing the integrity of the original album and sequence... songs within each of the separated albums are probably OK.
  19. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    #18 ⚡️ELECTROMAN⚡️, Jan 26, 2017
    So when you wrote:
    You were only talking about albums with multi-artists?
    You could always rename the artist field with one single duplicate name using a tag editor if it's worth the effort.
  20. rickgt
    Carmel
    Actually, the one that drives me crazy is the Original Cast album for Hamilton... For some reason, the Tesla USB software determines there are multiple artists (different characters signing different songs) and then separates it into several "albums"
    That's one aspect of the frustration of not being able to load and listen to an album like this in its original sequence.
    didn't want to waste your time.
  21. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    So with the Hamilton album the artist field for each song has the same name?
