2016 S75D from service center visit:
Confirmed low DC charging speeds in vehicle logs. Investigated cause and confirmed the battery management system has slowed the maximum charge speed due to high repeated use of DC charging.
This is a normal function of the battery to avoid loss of range caused by high DC charge use.
The DC charge limiting is set to start at 2625 kWh and reaches maximum derating at 13125 kWh. Your vehicle is at 15635 kWh as of the end of charge on the 17th.
The charge speed will not reduce further but continued DC charging will not cause a slow loss of range. This is a designed function to maintain the longest battery life possible. There is no defect.
This is terribad. As an S75D owner, I was looking forward to drive around Europe and stuff. But I guess I have to consider that again, thinking of future resale value etc.
2625 kWh before nerfing = ~35 0-100% full charges on SuC for a 75kWh pack, even less cycles on a 90 pack. Well realistically you would assume 15-80%, so on a 75kW pack that would be 49 kWh each time = 53 cycles.
So assuming you drive to a remote location every month (very light usage really), then use SuC both ways = 2 cycles.
Then, after only 26 months it will get nerfed.
Am I way off here ???
