A Better Route Planner vs Tesla route planner
jsight
759
564
Charleston
PLEASE don't use the Tesla website. It is not for trip planning. The car's computer is way more accurate.
However the car's computer is also not very efficient with the charging times on long trips. It stays at chargers for too long. You should be stopping more often and charging for shorter times.
I would trust ABRP for planning your whole trip then use the car's computer to plot to each individual supercharger stop.
I've noticed this with the Model X. The in car trip plan often had me at close to 20% at the next Supercharger. It was really inefficient compared to a shorter charge.
The weird thing is that it would estimate 5% for the next Supercharger, but it would jump by ~5% when I unplugged. Then it would gain another 7% or so on the estimate while driving.
The Y seems to estimate arrival percentages more accurately.
kurtatx
130
98
Austin, TX
That is exactly how I do it.
Yup! Road tripping an EV is a cool thing to brag about even though it's not all that difficult :)
There's literally little to no anxiety and all you have to do is wait a few more minutes if you would be more comfortable arriving at your next location with a bit higher SOC :)
chrisf60526
92
99
Chicago, IL
I have been testing ABRP out a bit lately and can only really look at it as an estimate. In fact, I don't really trust it. It's been off by about 20% for most of my trips.
Part of the issue is that it doesn't account for the colder temps unless you pay for the premium sub or manually enter it. Second, it doesn't account for higher speeds.
That being said, I think its the best thing going for estimation but I don't really trust it. What are others experiences here?
MorrisonHiker
S 100D 2021.32.20
Mar 8, 2015
10,127
9,627
Colorado
As the saying goes: Garbage in, garbage out. If it's off 20% for you, it's because you aren't entering all necessary values. We've used ABRP for years and it is nearly always spot-on for us. We do take a few seconds to enter in the speed and temperature manually but that's how we get accurate results.
Twiglett
Single pedal driver
Oct 3, 2014
2,983
2,950
Austin
that's my experience too.
If you enter that you're only carrying 100lb of addition weight instead of the actual 400lbs of people and luggage or that you max at 70 but actually cruise at 80 - then be prepared for inaccurate estimations.
With realistic data I have found ABRP to be pretty good.
Much better than the stunted in car nav.
I'm amazed that Elon seems to put so much faith in the in car nav - his insistence that nobody needs waypoints seems to have been a real blindspot for him to understand how people want to use their cars. It took a few years of incessant badgering but he finally got there.
jsight
759
564
Charleston
Make sure to turn on detailed configuration and enter accurate estimates of your speeding tendencies. You can also manually enter temperature, if you want to be that detailed.
If you are doing all of that and it is still off, you may want to look for inefficiencies in the car. Maybe your consumption is higher than normal?
msm859
396
594
Actually it is pretty sad that the "smartest" car out there is so bad at this. I have a 2014 Corvette that has NO problem accurately estimating my range - constantly adjusting based on my driving. And when I fill it up the range is based on my actual "history".
chrisf60526
92
99
Chicago, IL
Fair enough. Like I said, it's pretty good but with cold weather being a huge hit to EV's, the temp is something that needs to be accounted for. I don't use ABRP enough to justify the premium membership and i'd be curious as to how it handles the realtime aspect.
Reactions: jsight
KenC
3,701
3,361
Maine
As others have noted, you may be misunderstanding your options. You don't need a "premium" sub to ABRP to get it to give you accurate results.
Register for free, and login with your Tesla credentials so it can get the api data from the car. Lots of settings will be taken from the car. In the graphic below, the blue car icons with the wifi logo:
As you can see, it'll take your actual SOC, and it can calibrate your vehicle's actual efficiency, and it'll take the temp from your car.
bobby g
305
170
The Inland Empire :)
Newbie question ...
Picked up my M3 yesterday, with full navigation for the next 30 days, and downloaded the Tesla app ....as I am having my coffee and watching the news, I’d like to have the ability to route an upcoming road trip w/o going into the car. I’m sure I’m just missing it, but looked through the forums and can’t find reference to it.
Any one know if you can plan a trip via your Tesla app (like Waze) or do I have to be in the car using navigation?
Thanks in advance!
Waze can be used, no visual but audio via Bluetooth.
Also search an address, share, pick Tesla and it will pop up on your car's screen when you get in.
But, as everyone says, your car will prepare for a charge only if navigating to a SC. Waze for the trip, Tesla navigation for the charge
Grimm2017
New Member
Mar 28, 2021
PA
I have had a Tesla since 2013. I have never been stranded with a fully discharged battery. I have run out of gasoline numerous times. I have range anxiety numerous times on my Ducati with a 4 gal tank.,
I've been driving for 50 years. I've never run out of gas, ever.
n928kc
11
2
Massachusetts
So, I'm planning a trip to Vermont from Massachusetts in 2021 MY AWD LR.
Trying to use ABRP but I cant seem to find planning for round trip range and consumption option. I can plan each direction but it would be helpful to do a round trip feature to see what I need to do as far as charging. Each leg is 148 miles. the weather is 40ish and there are mountains involved.
any help is appreciated
MorrisonHiker
S 100D 2021.32.20
Mar 8, 2015
10,127
9,627
Colorado
Just add your starting point as another waypoint. MA -> VT -> MA
Reactions: GtiMart
surfrasch
349
164
Hollis, NH
honestly you don't need ABRP up to Vermont including mountains.....148 miles in the 40's, you'll be fine. There are superchargers directly off 89 and 91, at the major towns. Just keep an eye on your range as you're driving, see how far the superchargers are from you on the GPS, and leave yourself some extra due to going up hill. On the way back, you'll do better rolling down hill. Piece of cake.
Reactions: Rocky_H
