Re features: the thing that stops me using ABRP as my first choice is the wish to pick Chargers I want to use. I would also like to be able to say how much I want to charge there (I guess setting the %age would be OK, as that would then show the Time - so stopping for Lunch or somesuch would work. The "Long stop here" does work for that, but not if I need to use the same charger on Out and Return legs as it sets them both to a long stop. I think that feature is now a bit stale, sorry!, and would be better replaced with the ability to "tune" the Route Details instead (coupled with being able to "Manually Add" a charger)
For example:
Check how much longer a route would be if I went via Charger-X instead, or where EVTripPlanner has a different suggestion.
Check on splitting a charge - e.g. route tells me to charge, on return journey, to 74% at 135 miles from home. That's fine (and no doubt optimal) but chances are I will be in slow traffic and I would like to add a charger closer to home (which I can skip if it turns out I have enough charge to get home).
Using EVTP and adding that near-home supercharger adds 6 minutes to journey (getting to/from charger), splits the charge to 13 minutes at that charger, but overall that reduces charging time by 6 minutes (keeping max charge to Taper at the earlier stop). The journey times are, actually, identical. Now ... if it turns out that I don't need that final charge I will save the extra 6 minutes detour and the 13 minutes charging time
