A/C fan making loud noise
Discussion in 'Model S' started by Qttire1, Jun 21, 2016.
Tags:
  1. Qttire1
    Qttire1 Member
    Virginia
    Just took delivery of my 2016 model s with the new front facia. 2 days in cranked the a/c on high and a loud noise like the fan was loose or vibrating. Anyone else have this problem, looks like I have to take it back in to check it out.
  2. mikedc813
    mikedc813 Member
    Miami
    I have experienced the same thing in my 2016 MS. I have not had it looked at yet but others here have commented that they were told it is "normal" by their SC. I still plan to have it evaluated when I bring my car in for some other items that need attention soon...
  3. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    the a/c is crazy loud and seems even louder than odyssey because their is no engine noise. I do wish they had spent some more engineering time on making the a/c much, much quieter.
  4. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    It does double duty cooling the interior and the battery. The battery takes much more work than the interior. That's why it is so loud. Since it's pretty much the only noise it makes, it seems even louder than it is, which is LOUD! I have gotten used to it and it doesn't bother me anymore.
  5. Qttire1
    Qttire1 Member
    Virginia
    Talked to SC today and scheduled for them to take a look at it in a couple weeks. Sounds almost like when a computer fan goes bad and makes that loud noise. I'm sure its not supposed to sound like that. Will post back after service takes a look.
  6. MisterEman
    MisterEman Member
    SW Michigan
    I have a 2014 Model S P85. At start up in the Summer (I live in Michigan), the fan will hum noticeably. But after about 10-15 minutes, as the car/battery cools down, the humming gets less until it goes away. Since the car is silent, this is noticeable. But I only get this less than half the year since I live in the frigid Midwest. And it's only for a few minutes. No biggee.
  7. whitex
    whitex Active Member
    Seattle area, WA
    Does it sound like a playing card in bicycle spokes? If so, something may be caught in the fan. When I picked up my new car I noticed the loud noise. I knew the AC can be loud but it was much louder than my old one, so I stopped by SC. When the tech came out, he opened the frunk, reached in and pulled some label sticker, which apparently came loose from something else. Problem solved.
  8. Jurnimon
    Jurnimon Member
    Boston, MA
    The sound from a P85+ I drove for several days was loud but was much more refined than the sound I hear from my 90D. It's been quite hot here in Massachusetts lately and perhaps the system is working hard to cool the battery and occupants. :)
  9. FloridaGary
    FloridaGary Member
    Orlando, FL.
    Since we have been experiencing 100 degree days in O town lately, I would use the app to turn on my AC about 5 minutes before I leave. The first time I heard it, I actually thought someone dropped a hemi engine in my frunk it was so loud.
  10. Fusion
    Fusion Member
    San Francisco
    Mine sounds like a airplane and vibrates like crazy when the AC ramps up past the 5 speed setting. If I dial it 3 and under then it sounds like a regular car. Guess it's time for me to schedule a time to bring it in.
  11. FloridaGary
    FloridaGary Member
    Orlando, FL.
    Yes, it almost sounds like an engine running at higher rpm's. Try to convince someone you don't have an engine and they don't believe you it's so loud :(
  12. theslimshadyist
    theslimshadyist NashVegas!
    Franklin, TN
    At times when out driving my 550i and I return home, it sounds like an aircraft due to the fan cranking up, even after I turn the car off. Perhaps it's some auxiliary fan trying to cool the components?
  13. scottm
    scottm Active Member
    Canada
    Anybody with a Classic single motor S dig around yet under the frunk bin to find the A/C compressor?
    Mine has really picked up in volume when it's working hard... it seems like it's vibrating more than it should... and I'm wondering if a bracket has come loose?
    If it's relatively easy to get at, I would gladly tackle the job of tightening it myself.
    Anyone done that?
