A/C Problem
Discussion in 'Roadster 2008-2012' started by Pantera Dude, Mar 31, 2013.
Tags:
  1. Pantera Dude
    Pantera Dude Member
    Long Beach, California
    My air conditioning is either on or off, with nothing in between. The fan always blows as it should but with the temp knob anywhere except the full hot position, I get cold air 100% of the time. The compressor is either on or off, it does not alternate back and forth. Does this sound like a bad switch at the console or could it be something else?
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Sounds like a bad thermostat.
  3. Pantera Dude
    Pantera Dude Member
    Makes sense, I'll see if I can find it, though I haven't even found the evaporator yet! :biggrin:
    Thanks
  4. hcsharp
    hcsharp Active Member
    Vermont
    Mine switches on and off as needed.
  5. W8MM
    W8MM R1.5 #325 + Mdl S #01380
    Cincinnati, USA
    Ours switches on and off with demand. The only problem is it can't keep up with demand. We have a Roadster 1.5 -- the price of being early adopters.
  6. bart513
    bart513 Active Member
    East Hampton
    Anything that Tesla can do about that in the 1.5's? I'm getting my 08 shipped in a few days.
  7. Pantera Dude
    Pantera Dude Member
    That sounds crazy! I've never heard of such a thing? If that is in fact the way they work, I may have found the reason? It appears that all the hardware for the system is in the front trunk, so the things might not even have a thermostat?
  8. pbrulott
    pbrulott Member
    Montreal, Quebec
    I have a similar issue I think
    During the beautiful spring days, I like to put ventilation on to get some fresh air from outside while driving on the highway (don't want open window noise). So I set my climate control to ON, A/C off, circulation from outside, vent speed at 3 and temp at LO.
    Instead of getting fresh air from outside, I get super cold air. And I assure you that A/C is set at OFF. So anytime climate control is ON, I get air conditioning. I just don't get it
  9. Pantera Dude
    Pantera Dude Member
    Is your car a 1.5, 2.0, 2.5?
