Yeah, I tend to agree with you. I read the article this morning and I keep going back to this thread to try to post an opinion, but then I give up because I can’t quite decide on what my opinion is.
I have a big saltwater reef tank and I think that would probably be my tier 1 super critical load. If that loses power for too long I could lose thousands of dollars in livestock. Some of which I have had for years. Of course, the fridge is also up there in the critical load department. And I was able to experience running Tier 1 loads only after hurricane Matthew 4 or 5 years ago. I got a small 1800W inverter generator before the hurricane which was able to run the fish tank and the fridge and not much else. After the hurricane hit I had no property damage, but I did lose power for 3 days. And I can tell you that three days of critical loads only is pretty miserable. Especially in Florida when it’s 90+ degrees and super humid.
After that I decided that things like central AC and hot water might not quite be tier 1 critical, but they are definitely close. When hurricane Irma hit I knew I didn’t want to go through what I did with Matthew, so I wound up buying a much larger 7500W portable generator. This was a big step up from the small generator. It was able to run my central AC, as well as my water heater and even my stove (although not at the same time. I’d have to turn off the AC if I wanted to run the water heater or cook something. It also had the disadvantage of needing to be wheeled out of the garage and manually connected to the house and started in the event of a power failure. Luckily Irma didn’t take out my power at all, but I did use that generator for a few multi hour power failures, including one that was about 8 hours during the day. Being able to keep my AC running definitely made things a lot more convenient. I think this is more of a Tier 2 solution as described in the article.
However, I knew that I wanted more than just that generator and that’s where the powerwalls came in. I wanted something that could take over and power the house without any manual intervention. This was especially important for the fish tank in case the power failed when I was not home. I also wanted a solution that ideally would allow me to run the house the way I normally do whether the grid was up or not. Solar and powerwalls seemed like a good solution here, especially if they could help me save money on my power bill every day. It wasn’t a huge deciding factor, but I do also love the environmental factor as well.
I have yet to get through a real power failure with my powerwalls, but I have definitely determined that I am able to run my system off grid for extended times with little to no change in how I use power.
So all that said, things are going to be different for different people. And the type of outage you are planning for matters too. In my case it’s not uncommon to lose power for days after a hurricane, so I want a solution that will be able to keep me comfortable for days until the power comes back on. If you’re just planning for an outage measured in hours then it would be much easier to get by with just tier 1 loads.
