I wonder if the 'small' tesla is waiting for big volumes of the 4680 battery as a key enabler of a 'City' car?
A couple of things make me think this, first and most simply, structural pack and castings will be important for keeping the BOM down, therefore keeping the cost down.
More complicatedly, the charge rate enabled by the 4680 is really important. One of the things that small EV's are fighting with is that you either go small pack (ala mini-e, the otherwise beautiful honda etc), which is light, fits easily in a small car, and just makes sense for a city car. Or you go for a bigger pack to hit around 200 miles (corsa and similar), but then you are carting that weight around the 90% city driving you do, and the owner is having to pay for all those batteries and it mostly doesn't make sense. But you need the bigger battery to enable intercity travel because not only does range scale with batteries, so does charging.
If you use ABRP to try and plan a medium length trip in any of the 'city' rated cars its just super super painful. Some of them top out charging at 40kw. Which means that while you might accept that you will have to stop quite often if you venture out of your city, not only are you stopping, you are stopping for an -hour-, every single time. Drive for 90 minutes, stop for 60. Which sucks.
The 4680 addresses this by enabling higher currant and better cooling while charging - enabling a small tesla battery to possibly hit higher rates? An inside EV's article I found (just the top google result, not deep research), suggested that a full model 3 sized pack could hit 275KW for the first 50%. If we go for a small pack of 30kwh (would be over 100 miles in a model 3, could it be 150 in a small car?) it would be hitting 110kw for the first 50%, and still at 80KW at 70-80%.
Now you are at less than 15 minutes to reclaim 100 miles, and you can use the SC's so they are everywhere.
Still not ideal, but to me, that moves a small batteried 'city' car into one that you could, in a pinch, get around the country in. Drive 1.5 hours, stop for 15 minutes is muuuch more acceptable. You would be stopping every 3rd SC, rather than every 5th-6th.
Or is the small/second car's ability to get up and down the country if needed only something my family cares about?
