My wife just called frantically to say that she had received to following error whilst out driving:
Instructed her to return home without stopping. Once back home we tried:
1. Two scroll wheel reset - no change.
2. Vehicle power down - no change.
I popped the "mini grill" plastic cover in the front that allows access to the battery and wiper refill tank, etc.
Sure enough the negative battery lead was so loose I could remove it from the terminal with 3 fingers. Tightened it up. Error reset and no issues since.
We had an usually cold night last night (teens) which is probably anecdotal and not connected as the terminal really was super loose.
I'm documenting this here in case others have the same issue when searching for the error code.
