Ok. Here is a fact.
Just completed this journey in my LR RWD.
Temp was -6C, blue skies, roads dry, travelling at 114km/hr for 278km of total distance driven, with interior temp at 21C (however the last 25km or so the HVAC was turned off). Used autopilot. Moderate winds with winter tires at stock 18in config with areo covers. Also driven in Chill mode.
Average consumption was 200wh/km and 63kwh used. Travelled 315km with an estimated range remaining of 25km.
I charged to 99%(495km), preheated cabin while still charging.
So that means in the winter at mostly highway driving speeds, with a 1 1/2 hour stop for a meeting, i could go a max of 340km to empty. So that is a loss of 32%.
Not the 41% that AAA was stating.
However, this was perfectly charging to max while managing to preheat right at the end of the charge cycle. So i did not lose the customary 25km to the dreadful snowflake, plus 5 to 10km for preheating, as i normally would for day to day use. If i had not done this.. then i wouldnt have made it home without using a supercharger. Now, luckily the route i travelled has one nearby, so that wouldn't have been too much of an issue (+15minutes to the trip), but if i were to have gone somewhere else... then it would have been bad.
On top of that, almost no one charges to 100% on a daily basis. So my results do not reflect someone who may not have perfectly timed their charging with preheating (which would result in at least a 35km range hit), then run down to almost empty.
You ask for facts... yet you have ignored all of the facts i have provided you in my previous responses.
The AAA findings are correct for a large portion of the population that experiences a real winter. Is it possible to beat their findings??? Absolutely! I just did. But in my daily commute.. i see MUCH higher consumption.
