About the Door Handles
Discussion in 'Model 3' started by SageBrush, Jul 30, 2017.
Tags:
  1. SageBrush
    SageBrush 2018: Drain the Sewer
    Colorado
    They appear to be oriented for left hand use.
    Curious. Something to get used to.
  2. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
    I'm leftanded and use my right hand to open my drivers door. Strange that I'll have to get used to using my dominant hand.
  3. Twiglett
    Twiglett Single pedal driver
    Austin
    err - rotate your hand 180, now your thumb is on the other side, problem solved
    • Funny x 2
  4. Sonny Daze
    Sonny Daze Member
    DC
    Not on the other side of the car. :D
  5. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Many cars have/had push button door openers. What did y'all do then? Serious question. It's exactly the same movement. I would use the 'appropriate' hand for opening each door, no matter which 'handedness' I was or whether the door had pull handles or a button or this 'push one area, and pull the pop-out lever' setup.
  6. mrsandman
    mrsandman Member
    Los Angeles
    One of the videos mentioned that there were 2 ways to get out of the car. Has anyone figured out the 2 ways? I didn't catch the differences.
  7. boaterva
    Did they mean the doors? If they mean emergency escape, I would assume the trunk through the back seats, unless they meant something else entirely (trunks have an emergency open latch inside, even with a handle visible at night). The roof doesn't open. You can be trivial and say there are two doors.... :D
    How do you define 'two ways to get out of the car?'
  8. melindav
    melindav ☰ reserved
    Vancouver, WA
    are you thinking of this video? they mention there is a push button near where your thumb would be when your hand is on the grab handle and then there is also a pull lever (out of view but presumably under or within the grab handle)
    Edit: the Youtube time start didn't work - so fastforward to 1:40
  9. boaterva
    Ah.... yes, I heard one of the bloggers mention that, also. The lit button on the grab handle and a 'more normal' handle somewhere else. But not described in detail... I assume (like the emergency handles on the Falcon Wing Doors on the X) that they are completely manually operated and the buttons are electric and could fail?
    My confusion was from the phrase 'two ways to get out of the car'. My bad.... I would have said 'two ways to open the doors', sorry for the stupid answers above! :D
  10. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    As a right-handed Australian, I applaud this.
  11. BluestarE3
    BluestarE3 Active Member
    Norcal
    For LHD cars, isn't it normal to use your left hand to open the driver's door? This allows you to swing the door open past your body and step into the car. If you use your right hand, the door will bump into your body and you have to do an awkward contortion to swing the door open and then reposition your body so you can step into the car.
  12. mrsandman
    mrsandman Member
    Los Angeles
    Haha. Yeah. Sorry about not being clearer. I was just trying to state it in the same way the Tesla driver said it in the video from my memory.
  13. SageBrush
    Colorado
    Good point, at least for the front door on the driver's side.
