ABS system error
Discussion in 'Model X' started by Mikeballball, May 17, 2017.
Tags:
  1. Mikeballball
    Mikeballball Member
    Hong Kong
    Has any of you experienced these errors? I was driving normally and all of a sudden they popped up
  2. BestRadar
    BestRadar Member
    NJ
    I get errors like that all the time every few days.. My worst was the following:
  3. ToddS
    ToddS Member
    Jupiter, FL
    I got something similar after a failed update. Went away after updated properly.
  4. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    Could easily be an issue of one of the grounds failing.
  5. X Fan
    X Fan Supporting Member
    Naples, FL & OIB, NC
    Yes--
    Cable wire was loose under passenger front wheel well and sensor needed to be replaced.
    Needed a ranger to fix.
  6. number12
    number12 Supporting Member
    Tesla
    Isn't there a recall on some parking brakes?
  7. Mikeballball
    Mikeballball Member
    Hong Kong
    Wow I thought I had it bad, the thing is I was so used to the brake hold and it didn't register with me that this error negates this function so I almost rolled into the car in front of me during a red, they say diagnostics may take 2 weeks! Sigh. How long did it take them to fix yours @BestRadar
  8. BestRadar
    BestRadar Member
    NJ
    It has never gone in for service because it always fixes itself on the next power up. When I contact them they tell me they dont see anything out of the ordinary and I need to contact them during an event. At the moment its been good for the past 4 days. It comes and goes and the errors are always different.
  9. X Fan
    As I noted, I had same issue one night (with all your warning messages). Ranger diagnosed to passenger wheel well, found lose connector and replaced sensor.
    Btw; I was told that you should not drive far when you get those messages.
    I'd take pictures of screen when you get it again and call Tesla immediately.
    FWIW: probably similar to my issue & a faulty sensor......
