Hi All! Have any of you noticed that you had to turn your climate control 2-3+ degrees lower to obtain similar AC results was you did just a few weeks ago? John
Range Mode or Eco Mode? I think the HVAC system calls it Eco Mode. I have noticed the outside fan/compressor runs louder after the 2nd version 6 update.
I decided to turn range mode off yesterday. Then today I noticed that the fan speed, which had always peaked at "8" now peaks at "11". And it's colder. I don't know if this is v. 6.0, or just range mode. Anyway, the car stayed cool.
I'm seeing the effect on Range Mode and in normal mode. Both seem to require a lower set point to achieve the same effect. Vin: 9635
I know from past discussions with Tesla service techs that the Model S has had different cabin temperature hardware and placement through its evolution. So this effect we are seeing may be due to a bug introduced in v6.0 where the wrong temperature software is being used for earlier VINs. So, my vin is 5884 or so. For those that have noticed climate control issues, what's your vin?
I have never had range mode on and I checked and it is still off. Basically, I would keep the HVAC temp between 72-74. Now I have to go to 69 to get any real air flow and it is a bit disappointing even then. I just got back from having some work done at the service center. I wonder if it is related? Even when I put it to 69 the fan indicator shows ¾'s fan. Outside temp is about 85 FYI. I appreciate your assistance! John
Its supposed to reduce AC noise & installed on older cars upon request, if you didn't complain or don't see it listed on your service documents then don't worry about it.
