Accessing battery terminals for inverter attachment
will36
New Member
Mar 23, 2014
2
0
Australia
I have recently acquired a high voltage off grid inverter that I intend to attach to my roadsters battery pack. I fully understand all the risks involved in doing so however I am a very experience Electronic Engineer and the warranty is very near expiration. Before I go removing covers, probing for voltages and cutting wires, does anyone have any ideas for the best attachment of the inverter? or has anyone seen any blog entries/forum post of other people wanting to do the same/similar?
Ideally I would like to place it on the power module side of the ESS contactors (Which I am assuming exist???)
Also I assume the 3 cables from the power module are the main cables from the battery however does anyone know why there are 3 and what their polarity is?
Any help/ideas are much appreciated.
Will
hcsharp
3,370
1,337
Vermont
If you open up the access cover on top of the PEM you will easily see what's going on and where to attach your inverter. One of those orange cables has the wires coming from the charge port. You will have to have your car on in order to close the contactor from the ESS. Keep in mind the electronics are very sensitive. If your inverter draws too many amps it will create a lot of noise on the ESS wires into the PEM. That might cause problems.
It would be interesting to see your Wh/mi reading after running the inverter for a while without driving the car! Zero miles per kWh.:eek:
efxjim
231
29
Glendale, CA
There is a microswitch under the cover that throws an error code. When the switch is depressed the error goes away but Tesla has a log entry of the access. The switch could be held down with a thin plastic shim slid under the slightly loosened cover. What kind of inverter are you using? I would like to do the same thing.
will36
New Member
Mar 23, 2014
2
0
Australia
Thanks
Thanks for all your help. I have had a look under the PEM cover and that will be a very suitable attachment point!
The inverter is not for sale at the moment, I acquired it through R&D project. As soon as I get it working and get some more information I will let you know.
wiztecy
2,905
563
Wouldn't you need a 400 Volt (DC) to 12 Volt (DC) converter first, and where are you going to find that?? It appears you have one (an inverter of some voltage type), but how are you doing your conversion? And is this inverter also a converter? Basically reducing and converting the 400V (DC) source down to a 12V (DC) source then running your 12v (DC) source to 110V (AC) inverter in the US and most likely 230V (AC) in Australia. If not I'd suspect there's going to be allot of smoke, damage electronics (mostly on your inverter side), and open up a shocking hazard.
I was going to run an inverter off my 48Volt battery pack on my Zero motorcycle while I had fixed and enhanced the contactor, however in order to do that, I first had to find a 48Volt to 12Volt converter. Then from the 12 Volts feed the 12Volt Inverter. Was tough finding a 48v to 12v converter, so I buttoned up the pack and just riding the bike. I wanted to use the pack as an emergency backup power-source for my home and also when I go out camping.
jeremyz
257
94
Why can't you just use a solar inverter? They can accept 600V DC and output household current (assuming you want to power your house with it).
SUNNY BOY.SMA America, LLC
I guess that the solar inverter might find it confusing when it was trying to do maximum power point tracking (MPPT).
wiztecy
2,905
563
Thanks J!
That looks like the way to do it. I also found one that is 48V that'll work with the electric motorcycle:
Magnum MS-4448PAE 48 VDC 4400-watt 48VDC to 120/240VAC sinewave Inverter
Quite a hefty price, $2+k for the 48v input one on my link. This must be the path Will's wanting to go down. Not a bad idea having access to that power. Also a big advantage having the 2.0 PEM setup to easily access the +/- of the ESS.
spaceballs
629
99
Sammamish
*Warning do at your own risk.
If you want to do it for the cheap, use the the onboard ESS to 12v converter (it's ~2,000 watts), this I believe http://www.martekpower.com/products/en/ps2450.html, then connect cheap 12v to 120v pure sinewave inverter to I think these points.
Thanks J!
efxjim
231
29
Glendale, CA
Grid tied inverters need a stiff AC signal applied to the output terminals before they turn on. If this could be bypassed they would make a perfect backup/job site AC power source. I have yet to find someone who has successfully bypassed the safeties.
jeremyz
257
94
I was assuming that will36 wanted to use the inverter to buy cheap energy at night and use it during the day. If he wanted to use it off-grid, he might be able to buy an off-grid solar inverter. In Japan, you can buy an option for the Leaf to power your house when the power goes out at your house. There's also Via Motors' truck that can be used as a job site power supply.
wiztecy
2,905
563
What's exactly what I was thinking. But they are not. Two cables are the ESS poles and one goes deeper into the PEM, probably a charging cable but I don't know.
That sounds plausible. On the 1.5 the ESS run comes in on the passenger side and the charge port run comes in from the drivers side. I don't recall seeing anything clearly visible running from the PEM to the charge port on the 2.x's, But why one solid wire unless the 3 whires from the charge port are within it (single orange cable) which I doubt. But if that's just one (single) orange wire running to the charge port it appears to be way to big. Have to see pics showing the bottom of the PEM and the charge port wires coming out of the drivers side of the Roadster.
[update]
Here's a pic from the top of the 2.x PEM that should help clarify things:
