Is there an easily accessible way to probe the 12V power feed going to the PEM on a 1.5?
My Roadster sometimes glitches on key ON requiring the 60A cabin fuse to be pulled to reset things.
Measuring at the cabin fuse box the 12V rail is stable and clean (13.6V, ~100mVp-p) under steady load.
When the key is turned to the ON position there is a very short-duration sag of about 4.5V followed by an overshoot of about 3.5V. The APS starts to recover the sag in under 80ns and crosses the 13.6V line in under 200ns (sag is very very short).
Pulling each cabin fuse (one out at a time), including pulling the 60A fuse doesn't prevent the sag, suggesting it isn't caused by something in the cabin. Interestingly pulling the 60A fuse created a delay between the key ON and the CLICK from the PEM - the sag shows on the CLICK, not on the key ON.
If I can measure the sag close to the PEM that should definitively confirm it is the PEM turning on that is causing the transient load. If I need to add capacitance it would be best added before but close to the transient load.
TLDR: is there an easily accessible way to probe the 12V power feed going to the PEM on a 1.5?
Nick
Nick
