Active Ride Height
Discussion in 'Model S' started by NigelM, Oct 2, 2011.
Tags:
  1. NigelM
    NigelM Recovering Member
    Sarasota, FL
    So I spoke with JB Straubel at the Model S event and asked him a few questions about ground clearance which led on to the use of air suspension and active ride height. I call it active ride height as I am more used to hearing that term in Formula 1 racing where it was used for many years (before it was banned in 2010 to slow down the cars).
    JB basically described a system (air suspension) where the car adjusts automatically to car speed and road conditions and decreases/increases ground clearance as a way of improving efficiency and adjusting downforce, which will in turn improve handling even more. The system is smart enough to ignore intermittent roll (e.g. from cornering) and to only adjust appropriately. If the driver doesn't want to engage this (someone had mentioned a worry on another thread about ground clearance in northern winters) he/she can control the ride height manually from the touchscreen. This manual control also allows the driver to "lower" the car for unloading the trunk. Although Tesla is still deciding some of this stuff, it is my distinct impression that the Sig series will have this as standard and it will be an option for all others.
    I know there's a lot of interest and some of the rest of you will also have picked up info, so I created a new thread.
    BTW, JB also told me that in testing the Beta's had been easily exceeding 300 miles (guessing that's where the 320 number comes in). Final BTW, He's a very bright guy for someone who looks young enough to be my son!
  2. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    Will there be a "slammed" setting?
  3. Cobos
    Cobos S60 owner since 2013
    Oslo, Norway
    Thanks Nigel, it seems my fears that I couldn't use the car on Norwegian roads without constant worry can be put to rest. Then you can probably manually make a "winter" mode that is a few cm higher.
    Cobos
  4. mnx
    mnx 2013 P85
    Ancaster, Canada
    Now if only you could get your trailer hitch. ;)
    - mnx
  5. NigelM
    Sarasota, FL
    Cobos, I spoke to JB specifically about your question as you asked and he confirmed that there would be a manual control and that there was no need to worry about ride height in those northern (snowy) climates.
  6. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
    Also, one of the battery engineers assured me that they have been testing with all sorts of road surfaces and "deformities" (such as speed bumps/humps of varying heights/lengths) to make sure that the battery pack is kept safe from damage in all scenarios (unless one rides up a kerb!)
  7. TEG
    TEG TMC Moderator
    Do we know if this is a standard features, or an option?
  8. NigelM
    Sarasota, FL
    I asked but no clear answer, hence my earlier posting:
  9. tnawara
    tnawara Member
    Naperville, IL, US
    The Model S Features page states that the Air Suspension is optional:
    "The optional air suspension automatically responds to speed and road conditions. As Model S accelerates, it lowers the vehicle for optimized aerodynamics and handling. Lower or raise Model S using the touchscreen to unload cargo when parked."
  10. WhiteKnight
    WhiteKnight _____ P85 #549 _____ Sig Red / Sig White
    Atlanta
    From Tesla's Website:
    Option - not standard.
    Model S Features | Tesla Motors
  11. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    They assured me that riding up on a curb will not damage the batteries. I assume it would scratch up the outside of the pack.
  12. AnOutsider
    AnOutsider S532 # XS27
    I think I'd be embarrassed to even ask the question :biggrin:
  13. Cobos
    Oslo, Norway
    Thanks again Nigel, very good to know. I suppose many Canadians have it worse than we do when it comes to snow and winter so it's not like it's a special Norwegian feature. I'm really curious though on how the Model S will be received here in Norway next summer when you should be able to testdrive.
    Cobos
  14. NigelM
    Sarasota, FL
    I thought I had a pic of the battery tray, but apparently not and I'm sure someone has one. In any case, it's a huge lump of metal and looked more than sturdy to survive a curb or two. Don't forget if it's tough enough to add structure to the chassis it must be tough enough to stand up to a few rocks.
  15. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I have these pictures.
  16. Arnold Panz
    Arnold Panz Model Sig 304, VIN 542
    Miami, Florida
    I got the same response. I asked about speed bumps, road debris, curbs etc. and was told that they're testing it like crazy and subjecting the battery pack to all kinds of adverse conditions. They also said that if, somehow, the thick metal layer(s) was pierced and exposed some batteries, it wasn't terribly dangerous, and wouldn't hurt performance, but in any case there would be an alert on the dash telling you that there was a breach (like Star Trek!) and it needed to be fixed.
    Sorry for the non-technical description, but that's what I understood from talking to the guy standing by the base piece.
  17. doug
    doug Administrator / Head Moderator
  18. AnOutsider
    Hit me!
  19. Doug_G
    Ottawa, Canada
    Here's the bottom of the pack:
    It is VERY robust. The sheet metal on the bottom is pretty thick, it has reinforcing bars all along its length, and the outer frame is quite thick.
  20. vfx
    vfx Well-Known Member
    CA CA
    We were told that the ride changed 22mm. (3/4 inch) Pretty sure that was the driving amount of change, not the manual adjustment. When it was pointed out how that was not very much he said, It makes a lot of difference"
