Actual Driving Range
Discussion in 'Model S: Battery & Charging' started by JMO, Jan 23, 2013.
  1. JMO
    JMO Member
    Miami, Fl
    #1 JMO, Jan 23, 2013
    I have driven about 2,500 miles since November 13 2012 in my model S Signature.
    Lately I have noticed that the discharge rate is greater than the miles driven. For example, I drove about 48 miles today starting the day with a 232 miles range. I drove 48 miles and had about 150 miles left at day's end. Bottom line is that I had an 82 mile discharge vs 48 actual driven miles. A difference of 34 miles.
    I did drive on the highway 95% of the time and at speed averaging about 70 mph.
    So the question is: Is this a legitimate energy usage?
    JMO
  2. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    #2 aviators99, Jan 24, 2013
    I am editing my post because of math questions. You said you had a 70 mile discharge, but 232-150 is 82. Which was it?
  3. Zextraterrestrial
    Humboldt/Los Altos
    Sounds OK going 70mph.
  4. Nikoli
    Nikoli Member
    Cincinnati, Ohio
    I've been driving ~42 miles but discharging ~100. Cold weather is murder on EV range.
    Those in cold climates expecting to get the 40kwh pack should take note.
  5. napabill
    napabill Active Member
    Napa, California, United States
    Speed kills....range.
  6. schoendp
    schoendp Member
    Missouri
    Nikoli - that seems excessive, even for cold weather. Can you go into more detail about the type of drive, temps, use of heat, etc.?
