So I am looking to add a few adapters to gen 2 mobile charger for using with 240v found "in the wild". For sure going to get a 14-50, but are any others worth picking up? What do RV parks/campsites commonly have? Any recommendations appreciated.
In my experience, RV parks generally have the 14-50 available or 120V 30 amp TT-30. I got one of these to use with my Gen 1 14-50 adapter. Note you have to manually set the amperage to 24 amps when charging with the TT-30 adapter, since the car can't tell what you're using. Mine came with a label to that effect.So I am looking to add a few adapters to gen 2 mobile charger for using with 240v found "in the wild". For sure going to get a 14-50, but are any others worth picking up? What do RV parks/campsites commonly have? Any recommendations appreciated.
So the 14-50 with the TT-30 adapter would be the same as a 10-30 connector on the mobile charger with setting the amperage manually?
And I second this. Please get this real kind of TT-30 adapter that sets the current for you. We don't have to be barbaric with switching from 30 amp to 50 amp outlets and creating that kind of risk. This isn't 2013 anymore.If you want TT-30, buy a direct UMC adapter. The TT-30 to 14-50 are not safe to use, as you need to lower the current manually. If you forget to do that, you will trip the breaker in the best case scenario and start a fire in the worst case scenario.
TT-30 Adapter for Tesla
14-50 is a standard for campers with multiple air conditioners.
You'll also find it as an alternative plug at many locations.
Maybe the 15-20, but there are so Many J-1772 plugs around, you probably won't need much.
