Adapters for Charging in California?
Discussion in 'Model 3: Battery & Charging' started by Rosalind, Aug 1, 2018.
  1. Rosalind
    Rosalind Member
    Los Angeles
    I’m a new owner of Model 3. Haven’t charged away for on home yet. I have seen people post that they have a whole assortment of adapters for different chargers to use on the road. Apart from the ones that came with the car, are there others that I need to buy?
  2. Need
    Need Active Member
    SoCal
    The only one that you may use is the j1772 adapter that comes free with the car. You need that if you want to charge at ChargePoint or Blink or some of the 3rd party charging stations. There is also CHAdeMO adapter but they don't make it for Model 3 yet (only S and X). We have our Model X for 8 months and never had to use the j1772 that we carry in the car. There are so many superchargers in CA.
  3. gambit48
    gambit48 Member
    NorCal
    Yeah, if you live in LA, there are so many Superchargers around you won't need any adapters. Otherwise, the only public ones you can use that aren't Superchargers (which don't need an adapter since it's by Tesla for Tesla) is the J1772 Need talked about. The CHAdeMO adapter doesn't work yet like he said, and it costs like $500 so may not be worth it based on where you live anyways.
  4. Rocky_H
    Rocky_H Active Member
    Boise, ID
    This is 2018 now. You don't need anything else. The situation was very different back in 2013 or so.
    • Helpful x 2
  5. Galve2000
    Galve2000 Active Member
    NYC
    has this been confirmed? It sounds pretty strange to me TBH.
  6. Rocky_H
    Boise, ID
    Yes, several people have tried the existing CHAdeMO adapter, and it will not work at all for Model 3 yet. It has to be some kind of software issue, but Tesla hasn't released an update that will enable it yet.
  7. GHammer
    GHammer What a long strange trip its been.
    Wren, Oregon
  8. Rosalind
    Rosalind Member
    Los Angeles
    You guys are so helpful! I'm driving up to Bay Area soon, but I expect that they should have a lot of superchargers around there, too. I got the PlugShare app and fingers crossed!
  9. Charlie_T
    Charlie_T Member
    Foster City
    The other adapters that Tesla sells in addition to the J1772, the NEMA 14-50 and regular 110 adapters that come with the car are used if you have a specific other outlet that you are going to be charging from. This could be a dryer outlet in your garage, an older outlet or some other special outlet you come across. You should be fine with the adapters that come with your car, and as noted above there are many superchargers in California.
  10. SJCSuzy
    SJCSuzy New Member
    San Jose, CA
    Our dryer plug is a NEMA 10-30 so we needed to buy an adapter for it. Our house is 50 years old so I'm not sure if newer houses have just a 14-50 or what but check your plug and see what you need.
  11. smartypnz
    smartypnz Supporting Member
    Monterey Peninsula
    Rosalind,
    You need to go to....
    supercharge.info
    - that site shows where all the Superchargers are located (worldwide) - working, construction and planning status. Very up to date.
    As of this message there are 557 open in USA 1337 open in World.
    Also, on your Nav screen, the Superchargers are shown in Red
  12. Bradbomb
    Bradbomb Member
    Los Angeles, CA
    I use my J1772 adapter all the time in SoCal because I’d rather charge for free than even pay for supercharging unless I need to quickly charge. Whole Foods in Burbank has 10 free Volta chargers right by my work. Also, when I went to an outdoor movie in Pasadena near City Hall, there was a garage with free charging and $5 flat rate parking fee.
    I have no way to charge at home or at work btw
  13. Rocky_H
    Boise, ID
    Since you asked about it, here's the info on dryer outlets. The change of dryer outlet types was fairly recent--about 1996. Before that, dryers used 10-30, which have the two hots for the 240V and then a Neutral line, but there is no dedicated ground. Not having a real ground has some conditions where it might not exactly be safe, so electric code started requiring 14 series outlets instead of the 10 series ones. So newer houses, since 1996, have 14-30 outlets for the clothes dryers.
    Receptacle Roundup IV: NEMA 10-30 and 14-30
