After doing some adjustments with the charging cable, I was able to get Tesla's original console (purchased through the online store) to work reasonably well with my older Galaxy S5 and newer Galaxy S7 Edge phones - both in protective cases. The phone would slide onto the exposed microUSB connector - and stay in place.
That isn't the case with the new console that came with our S 100D. The connector mount is now rubber, providing more give (which is probably a good thing). But because of that, under acceleration, there isn't enough tension to prevent the phone from popping off the connector.
Tesla supplies two sets of side mounting inserts - which don't work with the Galaxy S7 Edge, with or without the protective case.
Has anyone come up with a way to mount phones on the charging connector in the new consoles, when the supplied inserts don't work?
If someone had the ability to 3D print alternate parts, it should be possible to make inserts that would work with more phones (I'm assuming Tesla is supplying inserts that work with iPhones...).
