Obviously people's frame of reference is part of it, but there is no way to set current speed without disengaging the cruise - that is annoying, because using the gas pedal is often the best way to adjust speed when the speed limit increases. Also, no matter how one thinks about it, it is illogical to have two ways of pushing the lever to set speed/engage the cruise (up or down). I would say these two observations, at least, are not really a matter of taste alone. The rest, of course, depends greatly on what one is used to.
Leaving the cruise always on is an option, of course, but the button is pretty easy to press by mistake (say, confuse it with the washer button) - so if you make a mistake, you won't notice until trying to activate the cruise... Also, that light is pretty annoying when it shines in an otherwise dark area of the car when one turns the wheel. Were it not for the light, I too might leave the cruise control on all the time, but even then, it is annoying if someone or something did turn it off and you didn't notice - you will only notice when the cruise fails to engage.
I guess I've been spoiled by better implementations in this regard.
