Using high regen in track mode is really helpful to save some energy. It also act faster when you are in heavy braking zone and save some heating. However when you release your brake the regen is still high and it often leads to some over braking.
It is also hard to “compensate” the regen in corners by lightly squeezing the throttle, considering the bad seating of Model 3. Some times my apex speed is too low due to the regen, otherwise too fast because I pushed the throttle too much when trying to reduce the regen.
So my idea is to detect the driver’s behavior to adaptively set the regen level when lapping. The logic should be really simple:
1. After heavy braking, set regen level to low. This tells the car you are slow enough and ready to turn in, no more regen needed until you accelerate again.
2. After the throttle floored, set regen level to high. This tells the car you are out of the corner and on a straight, prepare the regen for next heavy braking.
Hope they can add this to the next version of track mode. Maybe v2.5 or v3??
