We may be talking about two different types of control arms. A rear control arm, as radlaw asked about is not used to adjust the rear camber. You would use a rear camber arm for that. I answered his question referring to rear control arms, which you should not adjust even if you lower your vehicle. If you need to adjust camber, only do so using the camber arms. The rear camber arms are very different and they do come in handy after you lower the vehicle to get the right amount of negative camber in the rear. The rear camber is not adjustable with factory camber arms.
