well if we make it so each key have a default profile that is activate when you enter the car
and you can pin protect surtan profiles, so the "friend" / "valet" profile need to enter a pin to select a different profile
but you can still switch between your profile and the wife profile without needing a pin
and the you can set different limit on a profile, so I can make a profile to my friend
also a cool feature would be that the max speed is controlled by the GPS / navigation, as that knows the speed limit
also that it store the route on the map so you can see where it has been, and the color reflect the speed
and one more thing it would be cool if I can change profile via the phone, in case I forget to activate the valet profile
thinks I would like to set a limit on, via an option:
* change profile (pin)
* max speed (+10 i relation to navigation)
* max acceleration (0-60 in X sec)
* max distance from X,Y (valet can drive around the parking place but not leave it (it will come with a warning when i detect that you leave the area, before it stop)
* log max G force
* max volume (music)
* block web
* block driving history
* block navigation (so valet can get his thieve friend to clean out "home")
* set navigation to always show route back to where the profile was activated or location of your phone (when activated by remote) "patten pending"
* block or log access to glove box / frunk / trunk / 3 side doors / drivers door
* show that I will tip him if he connect the charger
