Adjusting Volume Wheel Drops Call
Discussion in 'Model S: User Interface' started by Ditpixs, Oct 11, 2016.
  1. Ditpixs
    Ditpixs Member
    Tracy, CA
    Wondering if anyone else has experienced this issue:
    I have the volume mapped to my left scroll wheel. When on a call, if I adjust the volume with the wheel it will drop/hang up the call. Using the screen works properly. I was suspicious of it thinking I pressed the button, but that is not the case as pressing that button is tied to the media player and not the phone app.
    This only started after the 8.0 upgrade. Using an iPhone 7 Plus, although I doubt the phone matters.
    Thanks!
  2. Max*
    Max* Charging
    NoVa
    Android Galaxy S5 and S6edge here. Neither of them can replicate the call being dropped.
  3. tgp1019
    tgp1019 Member
    Chicagoland
    It has happened to me on several occasions. I use iPhone 6+. Noticed this after I downloaded 8.0
  4. mattonlife
    mattonlife New Member
    Colorado
    Same issue, happens every time with iPhone 7, iOS10 and Tesla Firmware 8.0 (2.36.108) in my Mode S. Drives me nuts :) Has anyone reported to Tesla?
  5. JPP
    JPP Active Member
    SF Bay Area, CA
    Me too...but even worse, I am having BT issues with the audio of phone calls not routing through the Car audio. I have to disconnect and reconnect my iPhone 7, and sometimes also cycle the iPhone iOS10 BT off and on. PITA.
  6. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    Had similar behavior on my Nexus 6p although it would do it sometimes on 7.1 also
  7. M5Guy
    M5Guy Member
    Southwest Michigan
    Happens for me too. Currently version 8 and ios10 on 7 plus. Adjust volume, call disconnects. iOS 10 and v8 came out so close together, honestly can't tell you which one started the problem. Have not reports to Tesla yet, if it continues in the spring for annual service, will report then. Have just stopped using that during calls and use the touchscreen. Kind of annoying but not worth the 120 mile drive for me to Chicago service center...
  8. gnxs
    gnxs Member
    Chicagoland
    I have the same issue with a Galaxy S7, but it seems to be only on calls I make, not incoming calls. I reported it to the service support e-mail yesterday and they promptly replied with some follow-up questions. Then yesterday afternoon out of the blue my Service Center in Villa Park, IL called and the tech who was pulling my car logs had a question or two. Haven't heard anything further, but it looks like Tesla got right on it and are looking into it.
  9. SeminoleFSU
    Atlanta, GA
    I had a call drop on Monday right after adjusting volume. Need it to happen a couple more times in good coverage areas before I'm a believer
  10. taurusking
    taurusking Member
    East Texas
    Happened to me since upgrading to v8. I have Samsung Galaxy S5. Never had any issues touching left scroll wheel and call disconnecting before.
  11. Chas F
    Chas F Model S 60kWh #P6396
    Orlando, FL
    Same issue here using iPhone 6S.
  12. LoL Rick
    LoL Rick Like Buttah
    Land O Lakes, FL
    I've had it happen 5 times. HTC One M9.
  13. dabbler
    dabbler Member
    Toledo, OH
    Consistently drops calls for me using a LG android phone. I don't even have to adjust the volume. Glad to read that others are experiencing the same issue and have discovered a "work around" until the issue is resolved.
  14. Gmoney12
    Gmoney12 Member
    Harrisburg
    Same issue here. Really annoying. Any fixes?
  15. LoL Rick
    Land O Lakes, FL
    Got an update to 2.44.130 Tuesday night and yesterday I adjusted the volume without the call dropping. Just one data point but it was positive!
  16. bob_p
    bob_p Active Member
    Received the 130 update yesterday morning - and it disconnected me during a call.
    The call isn't dropped - what happens is the Bluetooth connection to the phone is dropped - the call was still on my phone, requiring me to hold the phone to continue the call.
    For obvious bugs like this, Tesla really should be acknowledging these bugs - and listing the major bugs fixed in each release - so we know what to expect - and what to report back as bugs to Tesla.
    Do they think this was fixed in 130?
  17. SeminoleFSU
    Atlanta, GA
    IIRC When this has happened to me in the past the car actually hangs up the call. It happens to me many mornings when I'm on a morning conference call walking out the door. I walk out to the car on speakerphone, open the trunk and put my stuff inside. Then I unlock the car so I can disengage the charging cable. Once the handles pop out the car Bluetooth connects to my phone. At that point the call is happening inside the car. I then open the door and before I get in the car I click the steering wheel button to mute my mic. When I do that the call ends.
  18. Markk993
    Markk993 Member
    Las Vegas
    happened to me twice in a row this week... HTC M10...
    Is there a fix in the works ?
  19. SarahsDad
    SarahsDad Member
    NC
    Has happened to me 3 times in last few weeks. Scroll volume, call drops. iPhone 6. All 3 were received calls.
  20. Atebit
    Atebit Member
    PA
    Yeah, well Agile doesn't work like that. Time spent documenting/tracking bugs takes time away from Tesla's ability to Continuously Inconvineince I mean Improve you.
    • Disagree x 1
