This is the advanced option thread, so please follow at your own risk.
With TSLA Volatility at the highest it's been over the last year with the exception of the recent drop to ~$250 it may be worth putting on a strategy that takes advantage of high IV.
Enter the Butterfly. One way to think of the butterfly is a long call spread and a short call spread, where the short strikes share the same strike. You make the most money on a long call spread if it's all ITM, the most on a short call spread if it's all OTM. These two strategies conflict each other so the Butterfly makes max profit right in the middle of these two, or exactly at the short strikes. Because you will almost never expire right at the short strike you will take profits at a percentage of the max profit.
One reason this is a great earnings trade is most long strategies are negatively affected by a IV decrease whereas a butterfly is usually set up to benefit as IV comes down. The closer an option strike is to the current share price the more extrinsic value it has. So if you choose a short strike not too far from the current share price, there is a LOT of extrinsic value that will go away thanks to two options being at the short strike. The way OTM long option won't have much value and if you choose an ITM long option it will have a decent amount of intrinsic value instead of all extrinsic value. Another great reason this is a good earnings trade is that most you will lose is 100% of what you risk. If there is a huge move up or down you might lose less than short puts, short calls, or stock, etc.
You can set it up so that the middle short strikes are right at the share price for maximum gain from IV collapse or move the short strikes up or down to be more bullish or bearish. You can also move the long strikes wider or narrower. As you move the long strikes out you have to put up more capital and have more to lose but your chance of losing 100% is drastically reduced. If you move you long strikes in closer you are putting up less capital, will have a much higher percent return if it is profitable, but you will much more likely lose 100% of your debit paid.
Here is an example of a slightly bullish BF, buying one June $275 call, shorting two $325s, and buying one $375 for a total debit of $17.5
Max profit will be at June expiration at $325. Breakevens are at $292.5 on the low side and $357.5 on the high side. To lose 100% TSLA would have to end in June above $375 or below $275. This seems like a reasonable range to expect TSLA to stay in between now and June based on recent developments. Achieving the max profit is not likely but shooting for 25% of the max profit is very reasonable. 25% of max profit would be a 46% return on your investment. You could either take this off right after earnings to make any money there is from an IV collapse or if you think TSLA is going to stay in the $275-$375 range keep it on and let theta decay do it's work.
If you are already super leveraged bullishly you can shift all the strikes down so that if TSLA drops in price you make money. You can also choose weekly expiration or May expiration to achieve a faster IV collapse but there will be less Extrinsic value to collect. You can also do multiple and layer, for example using some more bearish for short term expiration and some more bullish for longer term expiration.
Note: you WILL lose 100% using this strategy time to time so do NOT leverage up. This is a trade that should at most use 1% of your buying power in large accounts and AT MOST 5% in a small account, though I recommend much less.
