2015 P85D, 15k miles, warranty died on 3/31/23, bought it 3 weeks ago, in my possession for only 1 week, driven less than 20 miles.
Well, I suppose this is part of owning a Tesla. One week of physical ownership and here we go. The first 6 miles of driving was fine. Took it out this morning for another drive and on the way back home about a mile from home, I got the BMS_w035 alert. No hard driving and no higher than 65mph max. It drove fine all the way back home. Parked it and plugged in the charger. Shortly thereafter, checking up on the car also showed BMS_u016, then BMS_w172 showed up followed by BMS_u008.
Looked up many threads on this issue on here and it seems to be the battery coolant heater? It's been cold in my garage but nowhere near the sub-zero F degrees. Supposedly the 12v battery? I tore the front apart and looked at the battery. The negative terminal was a bit loose so I tightened that up. Powered down the car and powered it back up after 2 minutes as recommended. Same alerts remain.
I did take the car out and was able to drive it without issue albeit no regen and only under-100kW. Everything else seems to work just fine.
Is there anything I can do? I'm tempted to pull the 12v and the fireman's loop for a hard reboot since I've got the front wide open but I'm thinking that won't do anything. I'm 2.5 hours away from the closest SC. Can you replace the battery coolant heater yourself? Easy DIY?
I might just let the car sit for now and see if it fixes itself when the weather warms up (wishful thinking)? Any advice is appreciated. I'm guessing it's gonna go to the SC.
