AEB is radar based. Radar can only see things which reflect RF energy. Plastic and cardboard does not. You need to cover it in aluminum foil. Pull up to it slowly first and make sure TAAC sees it and you get a car symbol on the dash.
How about we get a TMC representative to sit on the engineering team that designed the AEB system and report back to us customers...
...We should question all of their claims. Why stop with AEB?...
Yeah I wish to see a test like that tooOkay, now who knows the specifics about at what speeds and other conditions AEB is supposed to engage? What materials?
This might not be what's happening here, but there was an old Star Trek episode where they tested a robot with an AI to see if it would stop a simulated problem that would kill it if it were real. It didn't. Later they discovered it didn't fail the test, it saw right through it, and knew there was no real danger. A bad AEB will not see a box and run right through it. A decent/good AEB will see a box and stop. A really good AEB will see a box and run right through it. Now I doubt the Tesla AEB is really that good, but depending on how it detects imminent collisions, it might not detect certain material combinations. This is an additional consideration beyond just verifying other constraints like at what speeds it's active, and it may only be designed to prevent automobile collisions presently.
That said, it would be interesting to see a full suite of tests in different conditions be performed against multiple different car brands that claim to have automatic emergency braking.
Note that this is not an easy feature to perfect. Make it too sensitive, and the car brakes randomly all the time. Make it too insensitive, and it doesn't engage when it needs to. I've dealt with similar scenarios before in programming. It's a difficult dance to perfect.
True, I'm considering putting some water balloons in there...I'd rather plow through an empty cardboard box than have AEB engage....
I don't think the shape matters, but yeah I should make it more radar reflective, will try that later lolI doubt the radar will see a cardboard box, and although the camera would see it, I doubt the software is trained to recognize that shape.
If I were doing this test, I'd look at making a soft object that looks like the rear of another car, and is radar reflective.
