The primary mechanism, for the increased efficiency from the Gemini caps, is the high pressure air within the wheel well gets blocked from escaping through the wheel. When the air passes through the wheel spokes it causes drag on the wheels turning. This is independent of the air passing outside the wheel.
The secondary cause for the increased efficiency is a smooth surface for air going around the wheel on the outside. The differences in optimal flow, due to the same cap being used on both sides of the car, is inconsequential and not worth the logistics and usage pain of having directional caps or wheels. Note that most Tesla wheel designs appear to have a "correct" direction but in reality are used on both sides of the car. Tesla makes no directional wheels or caps.
