I see, running 45 on 18 feels the same as running 42 on the 20 PS4s. I actually like the feel. I've tried running 45 psi on the 20" but it was way too stiff
Yep, it must all have to do with the wheels. I have 20k miles on my P3D- and averaged 250 wh/mile even with a lot of winter driving to ski areas. I run 18s. The P3D+ should be the same way and the slightly lower ride height might actually help it.
This looks awesome. I thought it would look strange with the different wheels front and rear, but it looks very experimental and futuristic like the McLaren Speedtail.I want to share a way for P3D+ owners to increase the car's efficiency. We all know that the stock 18" wheel cannot clear the rear caliper without grinding the caliper. So my solution is to use the aero wheel up front and try to find a light 18" wheel in the rear that won't clash with the front. I've found most of the Konig flow form wheel will clear the rear caliper so I decided on the Ultraform 18x8.5 +35. This result in a 50 wh/mi improvement!
Before:
20x9 +35 offset with Pilot Sports 4S (stock 20" tire inflated to 42 psi)
Averages 285 ~ 290 wh/mi on my mostly highway commute at 60 ~ 65 mph
After:
Front: Stock aero wheels with 5mm spacer to match +35 offset in the rear. Stock tire at 45 psi
Rear: Konig Ultraform 18x8.5 +35 with stock tire at 45 psi. Wheel weights around 19lb.
Same commute route averages 235 ~ 240 wh/mi
I'll update once I get more miles on this setup.
If you are running stock PUP Calipers and want 18" Wheels, I recommend looking at Enkei TS-V 18x8 +35 5x114.3. They weigh only 19lbs each.
Further evidence that tires matter for efficiency is that I have mounted 18x8.5" Weds Sport TC105N +43 (+38 with 5mm spacer) which weighs only 17 lbs each (41 lbs with tires) which obviously weighs much less than the OEM 20" wheels at 28 lbs each (53 lbs with tires). That's a total savings of 48 lbs of rotating mass and yet I have not seen a significant difference in efficiency. How is this possible? I am currently using 235/45/18 Michelin Pilot Sport 4S tires.
That's interesting because I feel like my car can coast further in neutral on these 18" wheels. I have not done any scientific tests, just a butt feeling.Because inertia works both ways. As you accelerate, the higher inertia will require more energy. However, at steady state, the higher inertia will help keep you going as much as slow down you. As you remove throttle, the higher inertia will actually carry you farther than a lighter wheel would, meaning that as long as you don't get into braking (meaning hydraulic, not regen), then you will benefit from the higher inertia while slowing down. Overall, it is likely a net minus, as the acceleration is likely more common, but particularly at steady state, there won't be a difference at all.
I'm interested in the aero's only for trips. Lots of elevation around me which makes a difference. I get around 220 miles of range on the highway. Would love to increase that, and put the fun tires back on for daily driving.
That's exciting stuff. I'm glad to hear that those numbers are achievable with the P3D+.This is what I like to see. As much as I enjoy tracking my car, I want the most efficiency I can get on the street.
On my P3D+ I installed Tire Rack 18X8 Sport Edition A15's (No Longer Available) which barely cleared the rear caliper. I'm running the stock 18" Michelin MXM4's. I also installed a UP Front Lip and have a UP Rear Spoiler on Order. MCS Coilovers dropped the car about 1.5" from stock.
This resulted in about 255wh/mi at a steady 75mph (no headwind, minor elevation changes). A massive improvement over stock P3D+.
I purchased another P3D+ for my wife last month, and am installing my Model S Caliper Retrofit Kit on the front axle (total of 6lb saving over stock) and stock base calipers on the rear axle (my wife will never need the performance brakes). This means I can run the stock 18" Aero Wheels and Tires! I'm also installing a UP Front Lip, UP Rear Spoiler, and Eibach Pro-Kit Springs. Finally, I'll be installing my Rear Diffuser (and recording before and after results). I'm hoping this will get me below 250wh/mi @ 75mph.
Good find on crossclimate+. Please report back on how they do.
Some people say 92 on 18” are fine. But I prefer play it safe. If anything for insurance, liability and warranty. I don’t want to hand anyone excuse for their responsibility, regardless if it’s technically ok.
What Tesla did looks like no accident to me.
Konig Dekagram 18x8.5" ET35 wheels
Where did you purchase the Konig Dekagrams ?
Discount Tire. They were out of stock initially, but I just back-ordered them.
Thanks for the detailed summary. I very much look forward to your efficiency report. Since your rims are also 8.5" like OEM 18", would the rim rash protection be the same or better than stock setup? Obviously there stock MX4s rash the rim before the tire which I hate....I have installed my CrossClimate+ tires for the brutal California climate. (I'll take them off in a couple weeks.)
Konig Dekagram 18x8.5" ET35 wheels with 235/45R18 CrossClimate+ tires. Stud centric mounting; no spacers, no hub-centric ring. Forgot to weigh the new wheel/tire combo but I think it's about 7 pounds savings per wheel (45 pounds vs. 52 pounds). Managed to use the stock lug nuts, but it's not recommended as it is easy to scratch the wheels. Replacing the stock 20" PS4S.
Efficiency:
I have benchmark routes to and from work that I take without AC on and try to control as much as possible.
On these routes, the tires appear to have improved efficiency by about 20-30Wh/mi - looks closer to 30Wh/mi, which is exactly what I expected. I will re-benchmark with the PS4S when I put them back on just to make sure it isn't related to software updates or anything else.
I've reset my recent trip meter (I was at 263Wh/mi over the last 1600 miles on the PS4S). We'll see how that does the next couple weeks then I'll put the PS4S back on.
Ride Quality:
Quite a noticeable harshness (high frequency jitteriness) improvement over the PS4S. This is not a surprise.
Overall the interior seems slightly more quiet and smooth. It's quite pillowy.
Handling:
Pretty squirmy and squishy compared to the PS4S. It's like driving on pillows. No surprises.
Didn't see to have any problem accelerating fast, but I haven't done a timed 0-60 run. I would expect no traction loss for acceleration though obviously braking will be compromised.
Noise:
I did just a brief freeway run. There was no noticeable humming at 70-80mph. I did go over a grooved surface on an interchange, and there was a brief resonance that may have been better damped by the PS4S. But on standard concrete and asphalt surfaces, they are really quite quiet. I would say probably quieter than the PS4S.
General impressions:
Compared to the MXM4's appearance, the sidewalls on these tires are a bit more bulbous. So I would imagine that could make aero slightly worse. Tread pattern looks pretty unique. Nice to see that mountain snowflake. Wonder if these tires will ever see snow? Looked like 9/32" tread depth to start with.
I'll do some more driving and report back my average efficiency over the next couple weeks.
Thanks for the nice review of the Michelin CrossClimate+ tires. I've been considering the CrossClimate+, Continental ExtremeContact DWS06 and Michelin Pilot Sport A/S 3+.
Hi jkoya, what did you end up buying? I'm extremely hesitating in deciding between Michelin CrossClimate+ and Michelin Pilot Sport A/S 3+ now (50/50 and not even 51/49), and I would like to know your decision, so I can take your advice from that.
I live in Houston, TX, a dry area. However, there are a lot of heavy rains and thunderstorms here, in which the CrossClimate+ may have better grip and good performance, but the A/S 3+ is also doing well in the rain.
