after market wheels lug nuts, forged aluminum, steel or stainless steel?
Discussion in 'Model S: Interior & Exterior' started by dark, Jan 21, 2015.
  1. dark
    dark Member
    california
    I just found out the model s lug nuts torque is 129 lb-ft per tesla's specs. I took my car in for other things but they checked my wheel and told me my lugs are under torque. I am using forged aluminum lugs, and torque them to 85 lb-ft, I am really worry since I don't think aluminum lugs can handle 129 lb-ft.
    Some of us have expensive wheels, what lug nuts do you guys use? I am switching them back to forged stainless steel and torque them to tesla's specs.
  2. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I used the OEM stock lug nuts with my aftermarket rims and yes, they are torqued to 129 lb-ft as per Tesla specification.
  3. linkster
    linkster Member
    USAX2
    #3 linkster, Jan 21, 2015
    2 years/44,000 miles here with 21 Turbines and Ronal 20s. I do tighten the stainless Gorillas on the Ronals less than the OEM covered lugnuts since the tapered seat area is reduced. Unfortunately, I don't have any hard numbers since I never use a torque wrench/stick on lugnuts.
  4. dark
    dark Member
    california
    Linkster, I have tapered seat also, and I don't think that should change the specs. The 129 ft lb torque is to pre tension the studs, i am guessing electric car has high torque which is different than gasoline cars where you torque it at 70 to 85 ft lb. I just replaced all my lug nuts to high strength stainless steel and torque it to 129 ft lb.
    I bought a new 1/2" torque wrench and I have to put my body weight to torque the bolts. They are tight, and if you are using a 3/8" wrench, there is no way you can torque it to 129 ft lb.
