My JL XD600/1v2 amp turns on but blinks green for 4 seconds then solid for 18, repeat. JL manual says that this is the power up mode and audio is muted.
Here's how I have it setup:
Not sure if I should pick up an LC2i pro or if the amp is just bad at this point.
any advice is appreciated.
- I tapped the blue and black subwoofer speaker level wires right before they connect to the amp.
- These are then connect to the RCA inputs, the negative speaker wire to the white RCA (right input) and the positive speaker wire to the red RCA (Left input).
- 1 gauge power from battery to dual fuse block, 50 amp fuse (per JL XD600/1v2 recommendation) to 4gauge wire into the amp. Amp is grounded to the frame from one of the factory ground locations.
- Amp has ability for high frequency so no LOC needed (apparently)
- Amp is configured to turn on when the stereo starts up, which it does do. Just never gets out of powering up mode.
