You are in luck as I installed mine today!!!
You do not need to jack your car up or remove the wheels but if you do it will make things a bit easier. You can also jack the car up without removing the wheels as well. Otherwise, turn the wheel left and right as needed (I did this option...Car parked on the street!).
Here's the directions:
1. Remove all the trims in the frunk.
2. Remove the frunk well
3. Remove the bumper (3 screws and 1 nut on each side along with clips on the bottom)
4. Remove the large sensor harness from the passenger (right side) before you yank off the bumper.
5. Remove the fog light housing from the bumper, install new ones. Make sure clips are in the right slot, 3 screws each.
6. Plan your wiring, run it from driver side to passenger side. Tie down your harness with tapes or cable ties.
7. Do not attempt to get power from the Daytime running light...your fog lights will stay on even when your car is locked (don't ask me how I knew).
8. Remove wheel well covers.
9. Remove the side camera. You will tap the yellow (for Right side) and Teal (for Left side) wire. Use the compact T tap connectors.
https://www.amazon.com/gp/product/B07DFZ8CBV/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 Hint: use plastic removal tool as not to create paint scratch.
10. Mount the yellow wires from the fog lights in the wheel well area then put everything back.
11. Remove a lot of panels: right passenger side by the door sill, rear passenger side by the door sill, seat rocker panel, and the rear deck speaker panels. Note: you might have to remove the rear seat air bag panel and the panel that holds the rear deck speaker down as well. You need access to the very end of the rear deck speaker panel as there's a plug in there that you need. DO NOT remove the center panel where the front passenger seat belt is. It will be very difficult for you to put it back together.
12. The fog lights get power from the rear tail light area. Keep that in mind.
13. Ground your harness to the right side by the day time running light plug.
14. Run your thin cable to the right fender, exit thru a narrow opening to the door, then route the cable thru the plastic window seal. Make a hole and pass the wire thru.
15. Continue running the cable to the back. Slide the cable into the center panel where the passenger seat belt is.
16. Route that cable up to the rear deck speaker area. Remove old plug, put in new one as a pass thru.
17. You will have a very hard time plugging in one side of the plug. I recommend you sand the inside of it with a dremel and remove the two side edges inside the plug.
18. Test to make sure your fog lights are working. Check turn signals too.
19. Put all the panels back...this is the fun part.
20. Enjoy. Contact me if you have any questions:
[email protected]
First time doing it will take you 5-6 hours easily.
