Aftermarket hitch options
Discussion in 'Model X' started by sinhcredible, Aug 29, 2016.
Tags:
  1. sinhcredible
    sinhcredible Member
    Philly philly
    I bought an inventory MX and it doesn't have the tow hitch or accessory hitch. My DS said its not possible to add one at the moment. Are there any options out there to add an accessory hitch? I'm not looking to tow anything.
  2. Saghost
    Saghost Well-Known Member
    Delaware
    #2 Saghost, Aug 29, 2016
    What I've read on the forum in the past is that it's probably a Bosal part, so you might be able to find one that matches from there. Here's one thread on the topic:
    Towing without the Towing Package
    Edit: It's definitely a Bosal part - here's the data label off of mine, with Tesla and Bosal logos and some part numbers that may or may not help you:
  3. vandacca
    vandacca ReActive Member
    Hamilton
    I think he needs more than the Bosal hitch receiver, as I'm assuming that the inventory MX came without any tow accessory. Probably needs to get a third-party frame mounted hitch receiver, similar to what's available for the Model-S.
  4. Saghost
    Delaware
    I had the impression that all Model Xs had the mount for the receiver in them, but I could be mistaken. I guess the only way to be sure is for the OP to open up the cover panel under the rear bumper and see what's there.
  5. vandacca
    Hamilton
    There were 2 upgrades in the Design Studio:
    (a) Accessory Hitch (this is currently very similar to the towing package, but that may change in the future)
    (b) Towing Package
    If you paid for neither, I assume you get nothing. I wouldn't even expect to see a removeable panel under the rear end of the X.
  6. Saghost
    Delaware
    Maybe I'm confused - I thought the accessory hitch was included if you didn't buy the towing package.
  7. vandacca
    Hamilton
    Go to teslamotors.com and see for yourself. The Accessory Hitch is an additional $200. The Towing Package is an additional $750. If you don't select either, then I'd expect no frame-mounting hardware for towing is installed.
  8. Saghost
    Delaware
    Huh. You appear to be correct, but that's not the way I remember it being when I ordered. (Of course, that was four months ago and I wasn't paying much attention to that particular bit because there was no way I was ordering the car without the Towing package.)
  9. vandacca
    Hamilton
    What you're remember is that initially the Accessory Hitch was a free upgrade (then shortly later, it became a paid upgrade). But you still had the option to get an X without accessory or towing package.
  10. tinkoo604
    tinkoo604 Member
    Vancouver
    Did you end up checking the bottom of the MX to see if there any kind of receiver. I placed a deposit on a inventory MX and it doesn't have the towing package nor the accessory package. The dealer is giving a really good discount on it but I Would prefers have the option to put a ski rack as I tend to snowboard allot.
  11. Saghost
    Delaware
    As you can see above, I have the towing package on my X, so I do have a receiver in mine, of course. The question is whether cars ordered without towing or accessory packages has the receiver on it.
    I believe I've seen photos into the bumper showing a car without the receiver since the time of this thread.
  12. Darryl
    Darryl ModelXTracker.com Co-Adm
    Palm Beach FL
    There is more to towing with a Model X than just adding a hitch. The Towing Package option includes the hitch, the receiver, the wiring harness and software to handle it all. The software helps to do things like preventing the trailer from swaying and increases range. The accessory package option was never intended for towing it was just to be able to add the capability of carrying things like skis and snow boards and does not come with the wiring harness or software. Also, depending on the aerodynamic's of what you are towing it can reduce your range by over half even more without the towing software enabled. Even though the receiver was eventually changed to two inches for both, Tesla would never verify the support structure was the same. I believe they eventually deleted the accessory package as an option. You also need to realize at most Supercharger
    Locations you can't charge with a trailer attached unless there are no other cars using the Chargers. Hope this information helped.
  13. Maaz
    Maaz Member
    Torrance
    Is there any update on this? My dad would really like to add Towing to his model x
  14. madodel
    madodel X at the end of a rainbow
    Poconos, NE Pennsylvania, United States
    Tesla — Tow Package
  15. Maaz
    Maaz Member
    Torrance
    I knew I read something about this. Thank you. The head of pre owned sales here said it wasn't possible. Thank you.
  16. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
