Aftermarket radio?
Discussion in 'Model 3' started by insaneoctane, Jun 10, 2017.
Tags:
  1. insaneoctane
    insaneoctane Active Member
    Southern California
    With no apparent "radio" to replace, I don't see how you can use any aftermarket radio in the model 3. I hope Tesla offers a great radio since I don't know what you could do if it didn't meet your expectations...
    • Disagree x 1
  2. JeffK
    JeffK Well-Known Member
    Indianapolis
  3. Big-T
    Big-T Member
    Seattle, WA
    Will the base config have an amp to replace? What about a sub? Also I'm a bit worried my local yokel car pro's shop wouldn't know how to wire anything in a Tesla
  4. NoMoGas
    NoMoGas Member
    Los Angeles, California, United States
    A tesla is just a car, not the magical creature some shops pretend it is. It comes with a 12 volt power supply, a fuse panel, an ignition circuit. Not complicated for any compeent installer.
  5. Jason Bourne
    Jason Bourne Member
    Philly
    I have already begun research and investigating to upgrade the base sound system I plan to order in my Model 3. I think it is unlikely that a) the better radio will be available as a stand-alone upgrade initially, instead part of an upgrade package that I probably won't want most of, and b) whatever price one would pay for a better radio from Tesla is twice as much as what one would spend at a quality stereo shop for an aftermarket system.
    Since the Model3 will most likely have a 12volt battery, it should not be hugely difficult to install an aftermarket system. The installer would tap in to the stereo output signal either from the factory amp or, if it doesn't have one, the infotainment system and feed the stereo signal into either a converter and then on to an amp or amps, or it can be fed in to an amp that accepts line inputs.
    I am assuming the base radio will have full range speakers in each of the doors and that's it. So my plan is to buy a 5channel amp, upgrade the front speakers to a component set and mount the tweeters in the front corner of the door, directly replace the rear door speakers with coax speakers and add a 10" sub. I think the amp and sub will fit nicely in the frunk with a little room to spare.
    I am not looking for an obnoxious booming system. That was 20 years ago for me. I want something that sounds good for most music types at all reasonable listening levels, and sometimes that's quite loud depending on my mood. But I want fill bass, not booming bass. There are many high quality 5ch amp that produce great sound, are affordable and not very large.
    • Disagree x 1
  6. JimmyAZ
    JimmyAZ Member
    United States
    No Tesla except the Roadster has an easily replaceable stereo, but why not just go for the upgraded system? The S's is really good. It's not perfect as has been discussed in other forums, but I think it's great.
  7. SMAlset
    SMAlset Active Member
    SF Bay Area
    We recently had our MS in for service and got around to asking about the sometimes poor reception of our radio channels in our car. Asked about whether you could have a better tuner installed even if after market and basically the answer was no. Not interested in XM radio. While discussing the issue it was mentioned that the Model 3 wouldn't have an AM radio. Ideas was to use internet radio like TuneIn for some of those stations. Kind of shocked since not all AM radio stations are carried on TuneIn, TuneIn even on our phone hasn't always been that great, and gee AM is your local news and talk stuff. We just went to a drive-in last night in our MS and guess that will still be doable in a M3 as the drive-ins use an FM channel to broadcast the audio for the movie.
    Still don't get why our MS radio can't get as good of reception of local AM stations as our Toyota parked right next to it.
  8. ikjadoon
    ikjadoon Member
    Why Electric Cars Are Ditching AM Radio
    I've also heard the lack of a protruding antenna also makes it worse, but that's speculation as far as I can tell (could be right; I just haven't seen data on it).
  9. SMAlset
    SF Bay Area
    Great article. Thanks. Didn't realize the MX has eliminated it already. Personally hope NAB or someone else can work out a solution. I'm one of those people who mostly listens to AM in the car.
  10. hockeythug
    hockeythug Active Member
    Minnesota
    There are devices like the JL Audio CleanSweep
    A few of my AM stations are rebroadcasted on HD Radio FM substations now. Don't know if this trend is continuing though.
  11. SMAlset
    SF Bay Area
    I have to wonder how much bandwidth is available to go around.
  12. dsvick
    dsvick Active Member
    NE Ohio
    Holy crap, your comment made me realize we can go to the drive in now (after we get our 3) and run the heat when it's cold out!! Wow!! thanks
    Back to your regularly scheduled thread....
  13. jaguar36
    jaguar36 Active Member
    NJ
    Alot of the AM stations are available on TuneIn.
