After much reading, I'm still not convinced on which aftermarket suspension option will best meet my desired results of OEM height (or slightly less) and a smoother ride on my RWD Model 3. I don't care about the track. I'm looking for luxury grand touring car here or as close as I can get.
Here are my options and the pros and cons as I understand them:
1) Unplugged Performance Coilovers - Coilover Suspension Kit For Tesla Model 3 by Unplugged Performance
I'm leaning towards the Unplugged Performance Coilovers because they're the only option with independent height adjustment and I'm not interested in lowering my car. I've also ridden in a P3D with this setup and I was impressed, but people really talk up the MPP options as well, which I don't understand really when they don't have independent height and preload adjustment, so I wonder if I'm missing something.
So with my goals in mind, does anyone have anything to add? Has anyone with similar goals to mine found their perfect solution?
Pros: Independent height and spring preload adjustment
2) Mountain Pass Performance Sports Coilovers - MPP Model 3 Sports Coilovers RWDRebound damping adjustment
Cons: No compression damping adjustment$2295 + installation
Pros: Compression damping adjustment
3) Mountain Pass Performance Comfort Coilovers - MPP Model 3 Comfort Coilovers RWDRebound damping adjustment
Cons: Height and spring preload adjustment are not independent (more height=stiffer springs)$2350 + installation
Pros: $1620 + installation
No compression adjustment
No rebound adjustment
Stated goal is "lower your Model 3 without reducing the ride comfort", not added comfort
