Aftermarket Wheels for Roadster?
Discussion in 'Roadster' started by smorgasbord, Mar 9, 2019.
  1. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    Between one wheel falling over onto its face and not having done an upgrade to my roadster recently, I'm thinking of upgrading from my stock non-forged wheels to something better looking - and lighter. The Tesla forged wheels are OK, but what other alternatives might there be? My recollection is that Roadster wheels are not a common size/bolt pattern/offset. Post your suggestions (pics and links to sources welcome)!
  2. Roadster
    Roadster JdeMO Powered
    SoCal
  3. smorgasbord
    SF Bay Area
    Thanks, but that thread isn't helpful to me. When I search on the wheelpros site for Tesla Roadster I get a ton of wheels, but when I limit to a 40mm offset, I get only one wheel. Hard for me to know what will really fit.
    Does someone have the specs, including offset so I could search on my own?
  4. MLAUTO
    MLAUTO Member
    SW Florida
    front 16x6 ET25
    rear 17x7.5 ET38
    You can fit more offset on the front (I run +40 both front and rear) without any issue.
    The only problem is some wheels will hit the calipers on the front.
  5. smorgasbord
    SF Bay Area
    Thanks. I also found this thread: Aftermarket Wheels/Tires/TPMS :: My Enkei Setup (Photos & Info)
    But, I'd like something no heavier than the stock non-forged wheels I have today. I guess trying to do something custom is going to be the best option. Any suggestions on best sizes to shoot for? I'd like to get away from the Yoko 07s on the front (I'm OK with the AD08Rs on the rear).
  6. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
    Love those wheels.
    Can’t wait for summer when they go on after the unwrap.
  7. SignatureSales
    We might able to help you out. We can build a set of fully forged that weight under 17.5lb each for 17inch setup, since we are all custom build, our wheel will fit on your Roadster without any modification, hub rings, or spacer.
    I’ve sent you a private message, please check.
  8. hanknum
    hanknum Member
    Santa Barbara
    Here's what I'm doing...I found a direct bolt on 8 spoke wheel. No spacer or hub centric rings needed. They are 17x8 with 245/40 tires which are near identical dia to OEM. Also, with this tire/wheel setup it weighs exactly the same as the oem at 43.4#.
    I;m going to be putting the rear rims on the front with 205/40. I'm hoping the additional with up front will reduce some of the understeer. I'm also going to "plasti-dip" the rears that will be going on the front black. Once black, I don't think the difference in spoke number and twist will be that noticeable.
    Henry
