Move to Texas. You'll have more disposal income. Problem solved.
YMMV.Move to Texas. You'll have more disposal income.
@CreoUCLA Yeah Spec.B was where it was at! LGT with better suspension and the 6MT (+ torsen R180?) in later years. Plus dat red leather right? I was set on wagon and there was no Spec.B wagon... If there was I probably would've bought it.The 2006 Subaru Legacy 2.5GT spec.B 5MT was actually my favorite Subaru I owned. I felt it was the best blend of looks, daily driving, and performance (I also installed an 18G turbo + TMIC + tune, Cusco Zero-2 coilovers, 18" BBS RE wheels, etc.)... But I should have probably waited another year (2007) and picked it up with the 6MT instead.
That's a perfectly suitable statement to make, but I think everyone got riled up because you started with, "Personally, I'd stay FAR away from any wheel that required a centering ring...."
Without qualifying that it's just your personal preference, you made it sound like there was a safety/installation issue if someone were to install aftermarket wheels with centering rings (which is not the case).
Interesting. So I have to qualify all of my statements with "in my opinion"? Isn't this a forum that dedicated to sharing opinions?
You can choose to get "riled up" if you want - but it's only opinions being shared. My opinion is that wheels that require rings are a poor choice.
However, in Texas, those rings might get you killed.... ;-)
My issue was more that you didn't state why you would stay "FAR away" from aftermarket wheels that require centering rings (implying there are issues/problems with doing so, which there are not). There is a difference between, "I personally prefer to buy wheels that are hub centric/direct fit..." vs. "Personally, I'd stay FAR away from any wheel that required a centering ring..."
Again, that's a matter of opinion. (whether rings can present issues, which they definitely can)
I prefer to keep things as simple as possible - fewer (potentially moving) parts is better where possible.
What if we switch this up and have folks whom are running "affordable" setups post pictures of their setup?
The trade here is a highly reduced set of wheels you can consider. For instance, nobody within 100 miles of me sells Stance wheels. Also, I have found when you work with a retailer like this, they tend to be highly conservative on what they will sell you. I know none of them would sell me any of the wheels I actually run that fit just fine. None of the big retailers are going to order a set of custom drilled wheels for you, mount some tires, and then check fitment for something they aren't 100% sure on. You pay in terms of reduced selection and often higher price.That's why I suggested working with a brick and mortar retailer - it will be up to them to make whatever you might buy work properly, or make it right, and the buyer won't have to do any of the work that might be required.
I was looking at SSR,TSportline,Titan,Stance etc.
There is a huge thread on aftermarket wheels already. People will have very different goals for size, look, and what "affordable" is, so I don't know what the point of a new thread is:What if we switch this up and have folks whom are running "affordable" setups post pictures of their setup?
The trick is to get all your wheels the same I have 4 sets of wheels, all use hubcentric rings. But they all use the same ring (the super common 73.1mm CB), so I can just leave it on the car. And I have 100+ AutoX events and a few road courses on them.I have used hubcentric rings and never will again due to challenges with them sticking and bonding to either the hub or the wheel. I also have over 130k miles on lug-centric wheels, including lots of off-road time, plus now now including 3 Autocross events.
Centering rings are fine, getting cheap wheels that aren't properly load rated is a much bigger risk.Personally, I'd stay FAR away from any wheel that required a centering ring....
Is swapping 2x a year between summer and winter sets frequent enough to avoid centering rings seizing up on the hubs? (That's directed at anyone who feels confident in their answer/experience.)The trick is to get all your wheels the same I have 4 sets of wheels, all use hubcentric rings. But they all use the same ring (the super common 73.1mm CB), so I can just leave it on the car. And I have 100+ AutoX events and a few road courses on them.
...getting cheap wheels that aren't properly load rated is a much bigger risk.
