The limiting factor is the front. I have read in many posts by different people that 255 wide tires on 9" wheels will rub slightly when turning in reverse. Btw, those examples are for 20" wheels, with 9" 35mm offset.
Based on the referenced thread below, you can run at least a 245/40-20 tire.
You can try out different options with an online configurator: http://www.willtheyfit.com/
I just did a ton of research and ordered custom forged Vossen wheels for my 90D. 21 X 8.5 all four. +35 mm off set. Continental SportContact 5 tires with ContiSilent foam inside for reduced noise. 245/35R21 all four. 8.5 inch wide wheels for a little more wheel lip protection from the tire. Although my wheels are directional, I'll still be able to rotate front to rear.
