It appears the new cars come with the 32A EVSE instead of 40A. They are cheaper to buy, but it is slower. They are screwing people over that have 50A connection at home.
So being able to charge the same amount in 5 hours instead of 4 hours is screwing? I think it would matter a couple of times in the life of the car, and ONLY for cars that rely daily on that device for charging.It appears the new cars come with the 32A EVSE instead of 40A. They are cheaper to buy, but it is slower. They are screwing people over that have 50A connection at home.
They could install a HPWC on that 50A circuit if the 8A difference is that important, or buy the Corded Mobile Connector. For most people though it doesn’t matter what time during the night their car finishes charging.It appears the new cars come with the 32A EVSE instead of 40A. They are cheaper to buy, but it is slower. They are screwing people over that have 50A connection at home.
Perhaps. I don't use something labeled as a "Mobile Connector" for daily charging -- i think of it as something light-weight and portable to carry in the car for times I need to charge on the go. Compromises are made in the design to make it portable. Some of the compromises turned out to cause failures in long-term use, so rather than beef up the device forcing us to carry around a frozen garden hose of a cable, they cut back on the current flow.Easy for you to say when you have the faster brick. How about they take away some of your hp, you only use it a few secs at a time
Shafted would be to arbitrarily drop the amperage after you bought the caryup Tesla confirmed that new owners are getting shafted...
(current owners). That would be changing the rules mid-game and I would agree.. shafting you.
Tesla is doing this for safety reasons. Mobil chargers are for... mobil charging. I never run my mobil charger at 40 amps because it runs to hot.
Buy a wall charger.
Do you mean $$ reason? How many older EVSE had caught on fire? I used my 40A one daily for the past 2.5 years, my house hasn't burnt down yet. I have no reason for a Tesla wall charger because I have other electric cars and I only have 50A fuse
That's not correct; you just haven't been following it long enough. They actually had a recall of the 14-50 adapter first a very long time ago, in early 2014. Links here.They had a recall on some of the adapter, not the 14-50
There are a variety of reasons why I use my UMC rather than getting an HPWC at home:
1) I don't want to get ripped off because I have a Tesla. The Tesla approved installers wanted a lot more for a HPWC install than what a normal electrician wanted to install a 14-50 outlet. Mention "Tesla" and the price seems to double over installing a 14-15 outlet for my "inlaw's RV"
2) I don't care about difference in charge speed. I drive less than 100mi per day, and park for over 8 hours.
3) I might move, and I don't want to have to buy another HPWC for the new house (or worry about writing the removal of the HPWC into the sale contract)
4) I might get a non-Tesla electric car or plug-in hybrid at some point, and would want get a J1772 charger which could charge both vehicles, rather than the HPWC, which just charges my Tesla. Many J1772 chargers will plug into a 14-50 outlet.
The only time I put my UMC in the car is for emergency charging on road trips. I've driven ~2500mi in 2 road trips since I got my car 6 weeks ago, and I've used my UMC away from home exactly 0 times.
Just installed a 14-50 instead of an hpwc due to cost difference also. However, a lot of the cost has nothing to do with getting "ripped off" if you took the time to price out the materials yourself. The wire alone on my job for the hpwc doubled the cost of the job. The labor is basically the same.
I only have a 48 amp charger on my model X so no need for 100amp hpwc anyways, but I may add it to my existing circuit (50 amp) in the future so I can charge at 40amp instead of 32amp and keep the mobile charger in the car at all times.
You could do the same in reverse by removing hpwc and take it with you and swap correct breakers and add a 14-50 for new owner.
Having a plug for other brand vehicles and not needing to charge faster makes it all moot regardless, just putting this here for others to read also. I'm not a pro at this but I think I have it all correct, feel free to correct me.
