Air conditioner A/C doesnt blow cold
Discussion in 'Model S: Interior & Exterior' started by rekoh, Mar 22, 2013.
  1. rekoh
    rekoh Member
    Minnesota
    Maybe I am missing something, but turned on my A/C today for the first time, and it didn't blow cold.. at all. I reset the center screen? to see if that would do something, played with all the climate settings, nothing.
    Anyone else ever have an issue with their A/C? Any other ideas on how to fix??
  2. Dborn
    Dborn Confirmed
    Sydney, Australia
    Does the compressor come on? ( not just the fan). Does the system have gas? You probably need service to check those out for you.
  3. rekoh
    rekoh Member
    Minnesota
    Yes the compressor comes on. .. .. Not sure if it has gas?? I sent a message to my ranger. I will update when resolved.
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    Too cold here yet for a/c but when I took my Get Amped test drive last summer, and drove one in California last September, I was very impressed with the a/c performance. On high you could hang meat in there on the hottest of summer days.
  5. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    No offense, but I'm gonna take reports of great AC from people from north of the border with some grains of salt :)
  6. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Dude, this may not be Arizona, but it gets well into the 90's, and I bet you've never seen our humidity!
  7. jerry33
    Texas
    My a/c worked just fine in Texas when the temperatures were in the thirties a few days ago. I couldn't see the power consumption needle move either so it's not going to affect range that much. Of course, when it gets to 45+ this summer, it may be a different story.
  8. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    I guess you were going a metric conversion for those Canadian folks :smile:
  9. jerry33
    Texas
    Are you implying that everyone doesn't use metric?
  10. john01
    john01 Member
    Provincetown, MA - Mahopac, NY
    My AC is horrid! AC is set at 67 for hours but inside 79 (that's what my app says). Outside it was 79. Yes I have Pano roof. I have no idea what the temp is in the back seat but it has to be much hotter. I've complained yet I'm told it's normal.
    I drove a 85+ and it was cold on a hot sunny day.
    The heater on the other had is great.
  11. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Your AC is clearly not working.
  12. jerry33
    Texas
    This isn't normal. You need to complain up the chain. Start with [email protected]
  13. Ohms.Law
    Ohms.Law Member
    Baltimore/Washington
    Lots of AC problems here. 2013: brought car in because AC was waking the neighbors. Told it was a normal sound. Six weeks later AC stopped cooling altogether and SC finally fixed it. 2014: brought car in because AC was waking the neighbors (again) and was told everything is normal and fine. Six weeks later (today) guess what? Noise is even louder and no cooling whatsoever. Going back in for service again this week. Getting very tired of this.
  14. Dborn
    Dborn Confirmed
    Sydney, Australia
    +1. 40 odd years ago, when I lived in South Africa we went metric. With everything. Took us all a bit of converting but worth it in the long run. At least I understand, vaguely what you guys are talking about when you mention Fahrenheit!!
  15. mknox
    Toronto, ON
    Agree. I can cool my car down easily on a hot (90's) and humid day with it in Range Mode.
  16. Burt Court
    Burt Court Member
    Southern California
    On the lower "Custom Auto" screen, above the three dark blue AUTO indicators is a lighter setting called "Reset Auto" That one is like a MAX in ICE cars. In my case, it will freeze me out very quickly. Discovered by accident, really like it. I at first thot our A/C was poor but now really like it.
    Old Burt
  17. mknox
    Toronto, ON
    On my car, "Reset Auto" simply puts the system back in to full Auto mode, not MAX A/C. In my previous cars, MAX A/C would simply change the air to recirculate from outside air and, in some cases, bump the fan speed up a bit.
    The Tesla does seem to give a lot more preference to Recirculate when in Auto mode, but it will eventually flip over to outside air when in full Auto mode.
  18. SBerg
    SBerg Member
    Solvang, CA
    There seems to be a big difference in cooling with recirculating (better) vs fresh air. Set that to "auto" and see if that helps.
  19. Burt Court
    Burt Court Member
    Southern California
    sorry mknox that yours does not work as well as mine, especially since I'm in the desert of SoCal. I get a really cold blast of air thru all the ducts very quickly. Have to admit that most of my problems at first were all "operator error".
    old burt
