air conditioning always on 5
Discussion in 'Model S' started by ahmed1000, Jan 14, 2019.
  1. ahmed1000
    ahmed1000 Member
    Zurich
    Come rain or shine, my 2018 S 100D heating / air conditioning system always sets the fan speed to no lower than 5 in auto mode. Normal behaviour? I find it annoying loud frankly.
  2. MarkJ
    MarkJ Member
    Sheffield
    Agreed. Never below 5 no matter what and I also find it too loud at lowish speeds so manually change it.
  3. TonyT
    TonyT Member
    Orange county, CA
    I'd love to try it in a 2018 100D. My 2013 85's are in auto and seems to change depending on cabin temp. Noise goes away quickly once car gets to right temp. Have not checked to see what the speed actually is.
  4. Joelgjr
    Joelgjr Member
    Westlake Village, CA
    Mine stays at 5 for seemingly forever and then goes up to 6 if it decides the window defroster needs to be on
  5. kev1n
    kev1n Active Member
    SF Bay Area
    works fine in my 2014
  6. TS_Rob
    TS_Rob Member
    The Netherlands
    I have the same issues with my MS100D (March 2018), the fan always runs between 5 and 7 fanspeed with a lot of noise even when the cabin temperature is at setpoint. In my opion the temperature controller is not very acurate as well, but this issues where pressent car since I received the car and havent improved during the many software updates.
    They need to tune the PID controller for the temperature and fanspeed. Now I need to change the fanspeed en temperature on hourly/daily basis.
    In my Audi A6 I never touched the temperature or fanspeed controller, it was always at a stable temperature and I only heard the fans running when the car was realy hot or cold, when it achieved setpoint no noise at all and always a stable cabin temp.
    My temp is set at 19 degrees celsius (66 Fahrenheit) and sometimes I break down in sweat because of the heat and 15 minutes later my legs freeze. Hope they solve this to improve the comfort!
  7. Hood7
    Hood7 Member
    Georgia
    Whenever I hit the A/C button/icon at the bottom of the MCU or turn on the A/C remotely, the fan comes on at level 5. I never need it this high and it bothers me. So every single time, I need to spend extra time fiddling with the A/C controls on the MCU to turn the fan down to level 1. I really think it should come on at the same level as the immediately prior time that the A/C or fan was on. In the end, this is just an annoyance, but it's an annoyance that crops up all the time and is an unnecessary distraction.
  8. David29
    David29 Supporting Member
    DEDHAM, MA
    I never check the fan speed. And I have rarely noticed the fan noise unless I put on the defroster. But I am older (early 70s) and maybe my hearing is reduced? In any case, I have not noticed any difference despite using version 9 software.
    Version 9 has made it more difficult to tell what is happening with the AC, and nearly impossible to adjust it as you'd like, i do agree on that point.
  9. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Funny, mine always seems to revert to 1. Here in FL, that aint cool (pun intended).
  10. ArbitrageMan
    ArbitrageMan Supporting Member
    Northern Virginia
    Mine is always 5+
  11. TonyT
    TonyT Member
    Orange county, CA
    I check recently and noticed my car is actually setting to 5 or more, however I don't find the noise at 5 very loud. So my car has always been set to 5 or more in auto however I don't notice much sound.
  12. Joelgjr
    Joelgjr Member
    Same. When I’m in full auto it usually starts blowing simultaneously through defrost, main, and floor vents simultaneously with AC on and can 6. After 10 minutes it switches to either forward and floor vents or one or the other. AC remains on but fan decreases to 5
    What I do when it’s too much fan I put the system into manual mode
