Air conditioning suddenly fails
Discussion in 'Model S: User Interface' started by Harropbill, Aug 26, 2018.
  1. Harropbill
    Harropbill Supporting Member
    Bethesda, MD
    A/C in my two-month-old 75D suddenly conked out, fan and other systems operating normally. Has anyone else experienced this? What is likely cause?
  2. animorph
    animorph Active Member
    Scottsdale, AZ
    If it leaves a puddle of water on the ground when parked for a while and works normally after that it probably just iced up and lost most cooling and airflow. No problem in that case. It should pop up a warning box on the dash if it is cooling the battery instead of you, so maybe not that. If the airflow was still normal, it could indeed be an A/C problem that would require a service visit.
  3. Harropbill
    Bethesda, MD
    Thanks. I’m heading for service.
