Air suspension doesn't feel like air?
Discussion in 'Model X: Driving Dynamics' started by jay-bay, Apr 17, 2017.
  1. jay-bay
    jay-bay Member
    Idaho
    Hi everyone,
    So I thought that the air suspension was supposed to be a smoother ride vs. the coils? For some reason, it feels like the air suspension on my Sept. delivered X rides a lot harder than my Model S which had coils. Anyone else experience something similar?
  2. PedanticOne
    PedanticOne MyTesla Refresh Champion
    Bay Area, CA
    Which wheels did you get?
  3. professionalr
    professionalr Member
    Rancho Cordova, CA
    Didnt notice a difference either between them with the same wheels.
  4. jay-bay
    jay-bay Member
    Idaho
    I have the 20" stock wheels.
  5. PedanticOne
    Bay Area, CA
    I felt a definite difference between the Model S I had as a loaner with the low profile wheels and presumably coil suspension. I have 20" wheels and the ride to me feels fantastic in the X. Sure, rougher pavement might get a bit bumpy, but it seems pretty good to me *shrug*.
  6. jay-bay
    jay-bay Member
    Idaho
    Ok, just seems like I feel every pebble I run over. I also drive in the I-580 express lane on the freeway here in CA and I even feel the words written in the express lane.
  7. COrich
    COrich Member
    Colorado
    Air suspension is not necessarily softer that steel springs. What it provides is adjustable height for varying road conditions and better efficiency/performance at higher speeds.
  8. chillaban
    chillaban Active Member
    Bay Area
    I just upgraded from a coil equipped to an air Model s with same wheels, and the air suspension feels a bit smoother at absorbing bumps. But overall it feels quite similar. The main benefit of the air suspension is to lift the car for clearing curbs and hilly driveways. I think any perceived ride quality difference is subtle and secondary.
  9. jay-bay
    jay-bay Member
    Idaho
    Ok thanks everyone for your input. Very helpful!
  10. RichardL
    RichardL Member
    San Carlos, California
    I had an S with air, and now an X with air - and the X suspension is definitely 'harsher'. I have always liked a more direct feel, so it suits me, but there is a difference
  11. mohanman
    mohanman Member
    Michigan
    Yeah X is a rough ride. I would hope someday they send an update that allows us to adjust the stiffness of the suspension. That would be awesome
    Mo!
  12. PedanticOne
    Bay Area, CA
    I am amazed at the range of what people report as the smoothness of the ride. If you want a rough ride, you should get into a GT3. Or my old Jeep. :p
  13. goneskiian
    goneskiian Active Member
    Bellevue WA
    I've said this before in other threads but I too have noticed a difference between the S's ride and the X's. The S is both more planted (less body roll) and smoother at the same time (Yes, both had the air suspension). Likely due to it's less weight and lower center of gravity.
    I agree it would be great to get the X to ride and handle the same but physics may not allow that.
    That being said. I like the sporty nature of the X!
  14. jelloslug
    jelloslug Active Member
    Greenville, SC
    I felt the same way with the Model S.
  15. Milin1609
    Milin1609 Member
    Kingsland,GA
    I second you MOHANMAN. I don't like the bumpy ride of Model X. Wish, Tesla can make it bit softer via some software upgrade.
  16. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    Maybe the firmer ride on the X is because it is a heavier vehicle, is expected to carry heavier loads, and is configured for towing up to 5,000 lbs.
    I believe the wheels are also constructed heavier and sturdier than the S.
    I love the firm and well planted suspension on my X. Feel that they got it just right. Saw others in previous forum posts complaining that the air suspension in the S gave them a floaty feeling. X feels more BMW than Buick.
  17. kallekula
    kallekula New Member
    Sweden
    Does anyone know if this is technically possible?
  18. PedanticOne
    Bay Area, CA
    After paying more attention, I have to say the ride is not quite as smooth as I originally indicated. It's still pretty good, especially at slower speeds. I think high-speed compression is not it's strong suit. That said, I'm still very satisfied with the ride.
  19. mspohr
    mspohr Well-Known Member
    As far as smoothness...
    Because of it's low mass (low inertia), Air suspension is of primary benefit in filtering out high frequency road noise.
    Coils transmit these high frequency vibrations to the chassis more readily.
  20. calisnow
    calisnow Active Member
    Los Angeles
    The X ride is not as good as the S unfortunately. It's not *awful* but it could use a lot of improvement.
