Air Suspension failing on the same day someone hit me
Discussion in 'Model S' started by dohmer, Sep 25, 2016.
Tags:
  1. dohmer
    dohmer Member
    Burnaby, BC
    Hi,
    Just wanted to get some thoughts on whether the two are related or purely coincidence. I had my 2016 S parked in a parking lot (backed in). When I came out, I saw damage on the rear panel (passenger side) between the wheel and bumper.
    It was driving fine after that. I drove probably around half an hour since and when I was almost at home, I heard this loud sound (like something broke). Then I heard a hissing sound. I thought I punctured a tire but turns out it was the air suspension.
    The insurance now wants to know if the air suspension damage is due to the accident or not. This kind of determines where the car goes first (insurance adjustor or Tesla service center). I think it's just a coincidence that the suspension broke on the same day as I got hit but wanted to tap into the collective experience of the forum. The reason why I said it's a coincidence is that the damage on the body seems very superficial. No major dents to the body, just scrashes. And since the accident happened at a parking lot, the car who hit me couldn't have been driving that fast.
    Car was just towed away to the SC right now. Thanks in advance for any insight.
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Damage looks minor. Was the "hissing sound" coming from the left rear where you were hit?
  3. dohmer
    dohmer Member
    Burnaby, BC
    Actually it was the front suspension that broke. The sound seems pretty close to the front left side wheel.
  4. CmdrThor
    CmdrThor Active Member
    Marietta, GA
    I would tell the insurance company you have no idea and they should ask the service center what the cause of the suspension damage is.
  5. Drewflux
    Drewflux Member
    Australia
    Seems like just bad luck. The pant transfer marks indicates a very small rub.
  6. Bimbels
    Bimbels GoldMember
    Newport, RI
    Could the air suspension be adversely affected if the car was jolted of moved, by the impact, while in park? (BTW I know nothing about air suspension so honest question.)
  7. Todd Burch
    Todd Burch Electron Pilot
    Smithfield, VA
    I think it's possible it's related. (Air suspension failures have traditionally been pretty rare for the Model S over the last 4+ years).
    I agree it's best to let the insurance company know that you don't know, and let the service center figure out the cause for the failure, and see if the accident could have caused it. Everything else is just speculation.
  8. dohmer
    dohmer Member
    Burnaby, BC
    I'll update the thread once SC tells me the reason. Air suspension failure does seem less common especially in a <3 mo old car. Tow truck guy said he's never seen it before.
  9. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Good luck convincing Tesla that it's a warranty issue when you have bumper damage showing an obvious incident. I don't think you'll get far with Tesla.
  10. ecarfan
    San Mateo, CA
    You say there was a "hissing sound". Did you try changing the ride height using the center screen controls and see if the car raised evenly on all 4 corners, or was there an error message on the screen when you attempted to change the ride height?
    I'm wondering what evidence you noticed to indicate the "front suspension broke" other than the hissing sound.
  11. dohmer
    dohmer Member
    Burnaby, BC
    There is a one inch gap between front bumper and the ground. The tires are also almost touching the wheel well. Changing the height of the suspension doesn't change the height. it sounds like the hose to the suspension is cut off. The pump would turn on (even when car is off) to level it but nothing happens.
  12. dohmer
    dohmer Member
    Burnaby, BC
    I don't really have to convince them. If they say it's a result of the accident, then insurance will pay for it. I just went with them first since it doesn't look like it's related.
  13. ecarfan
    San Mateo, CA
    Wow. Your shock has collapsed! Lack of air pressure seems like it would explain that change.
    It will be interesting to see if Tesla thinks that happened because of the accident or not. As many have noted, your body damage at the right rear looks minor and the impact location is a long way away from your left front shock. Very odd.
  14. dohmer
    dohmer Member
    Burnaby, BC
    IMG_7590.JPG Here's a picture of what it looks like
  15. dohmer
    dohmer Member
    Burnaby, BC
    Service advisor said the two damages are unlikely related so they will fix the suspension problem under warranty. Seems service is pretty good so far. I'll know more about what exactly broke when I pick up the car next week.
  16. AMPd
    AMPd Active Member
    Northern California
  17. zambono
    zambono Active Member
    DC
    They might be rarer on model S but they are fairly frequent and expensive on other brands such as Lincoln and Land Rover
  18. Todd Burch
    Smithfield, VA
    I have coils for a reason :).
  19. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Some people pay good money to drop their rides that low. Just gotta get some wheel hub spacers to push your wheels out wider to complete the look. ;-)
    Glad to hear your service center did you a solid and took care of the air suspension issue as a warranty repair. As Todd mentioned, air suspension issues have been exceedingly rare.
  20. ecarfan
    San Mateo, CA
