Air suspension question
Discussion in 'Model S: Driving Dynamics' started by 787steve, Jul 24, 2016.
  1. 787steve
    787steve Member
    Cary, NC
    Our MS order just got confirmed. We have the adjustable suspension in the package, because we have a rather steep driveway, and I have hit too many parking lot curb bumpers in low cars before. I know that I can program the car to raise as the speed decreases.
    But I found a thread saying that an owner parked his MS, then the car lowered itself down till it was sitting on the curb bumper, which caused damage as he backed out of the slot. Can you set the system to stay in the high position after shutdown, or does it always lower when the car is off?
    Thanks
  2. Stiction
    Stiction Member
    United States
    I have air (April 2015 85D) and it NEVER lowers when I'm parked.
    I always leave the car with the suspension display up and verify it's still Very High (because of reading about these problems)
    If my car ever started doing that I would take it in and get it fixed..would be useless otherwise.
  3. 787steve
    787steve Member
    Cary, NC
    Thanks so much for your reply. I was assuming that was how it worked.
  4. jmsurpri
    jmsurpri Member
    Beaverton, OR
    The owners manual states that the car could self level even when the car is off. I've witnessed my car do a small adjustment to level when sitting in my garage. However it definitely shouldn't change the set level while off.
  5. 787steve
    787steve Member
    Cary, NC
    Perhaps if you parked with a big load, and unloaded, it will seek to level the chassis, but not lower the car. That might have been just enough to cause the problem in the post I referenced.
    Thanks for your input.
  6. purplewalt
    purplewalt Active Member
    Dallas, Texas
    My car actually remembers where (based on GPS) to raise the suspension.
    And it remains raised until I exit my parking garage at work.
    If I drive by that location (or a denoted similar location) at a higher rate of speed (not intending to actually park), the car beeps and issues a warning.
    The only downside is when I have a loaner, I forget to raise the suspension, and the car scrapes bottom at the ramp.
    Whoops!
    You should be fine, (unless you drive a loaner and forget).
  7. SD Diver
    SD Diver Member
    San Diego
    Totally love the air suspension. It remembers to raise itself approaching my driveway (very high), at work (high), and the local grocery store speed bumps (high). Also, set to low at 55+ mph. And you get the cool 007 Easter egg by entering 007!
  8. Ashkenaz
    Ashkenaz Member
    Ohio
    I love the air suspension. Also use it on some roads where construction taking place. I don't go to low at higher speeds but kept it at default of 100 mph or whatever.
  9. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    Just as a data point: My Signature S would *sometimes* lower onto the curb. It would take a second or two as the car powered up to air up the shocks again, and it would raise. But if you jumped in, hit Reverse, and pedaled backward, the front end would s-c-r-a-p-e off the curb.
    I haven't noticed it doing that with the 90D. This may have been one of those 20 improvements a week that Tesla had to build into new hardware.
  10. Moneesh
    Moneesh Member
    Yorba Linda, CA
    I picked up my new MS 90D two weeks ago and the GPS based air suspension works very well (as described by others). I too have a steep driveway at home. As I approach my street, about 100 yards from my house, the car raises itself and stays that way until I leave my house, at about the same location. There are several parking lots and shopping areas with high parking barriers, so I use the air suspension to automatically raise any time I go to one of my set shopping locations. I think you'll be pleased with the functionality. Enjoy your Tesla!
  11. 787steve
    787steve Member
    Cary, NC
    Thanks Moneesh. We are looking forward to it.
  12. LoL Rick
    LoL Rick Like Buttah
    Land O Lakes, FL
    If you regularly pull forward into a parking space and stop when then wheels hit the berm, then I'm going to suggest that you change your habits. Others have reported that their cars lowered after parking, and software changes regularly, so there is a non-zero chance that it could happen to you. It only takes once to rip off the underside of the bumper, which a friend of mine has done. There are two good alternatives to use instead of "nose in until it stops."
    1. Back in using the camera and lines. Seriously, this car is easier to park backwards than forwards. When the berm disappears from view, stop. If you continue, then it will bend the rubber fins that direct airflow by the rear wheels.
    2. When nosing in, look under your outside (door) mirror for the berm in the next space over to appear. As soon as you can see it, stop. This will leave the nose of your car in the clear. With a little practice you can do it even without a clear view of the space next door.
  13. 787steve
    787steve Member
    Cary, NC
    Thanks, I was thinking backing in is the way to go. But the one who must be obeyed isn't as comfortable backing in. I'll tell her about your mirror line up cue, and hope she can keep it clean and shiny.
  14. CKCland
    CKCland Member
    west grove, pa
    I just picked up my 60d yesterday and love the air suspension. Am still figuring it all out, but love the fact it raises itself based on GPS positioning.
  15. ediot
    ediot Member
    HONG KONG
    or, if your garage has a roof, just do a tennis ball set up...i.e.:
    get a friend to keep watch for you whilst you back your car in etc, until it's at it's ideal stopping point without the wheels hitting stoppers. get a tennie ball and thread a fishing wire thru it, then attach it to the ceiling in a way, so that the tennis ball just touches the windshield (or rear hatch window). from now on, you just have to back your car into the spot until the car touches the tennis ball. voila!
  16. wdolson
    wdolson Supporting Member
    Clark Co, WA
    I wasn't sure if I was going to like the air suspension or not, but it's great. I crank it up to full height for all the places I frequent. With my long legs cranking up the height helps getting out quite a bit.
