Tesla specifies a Low ride height when at highway speeds, so unless you manually change it to very low you will not get this added benefit they are claiming. I'm just trying to quantify it. The same thing is going on in the what's your 90% thread. Real world data from users (in controlled situations) helps substantiate claims of greater efficiency and so on. Wh/mile will either be higher, lower or the same as soon as you make the change manually from low to very low on the same grade of highway at constant speed, albeit winds may affect it slightly but over a decent length of road it would average out. Not necessarily comparing one driver to the other, same car same condition, only ride height is variable. We should see some interesting results since I doubt most owners are "manually" selecting very low.
