Alarming amounts of cold weather vampire drain
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
I think that if it needs to consume more power in cold weather when it's just parked that Tesla should be more transparent about this when they advise what typical loss is for purposes of leaving the car parked for awhile, etc.
Tesla is borderline aggressive with publishing the amazing savings you will get with a Tesla 3 vs. the ICE competition. Certainly a Tesla should be cheaper to operate at least during the warranty period but Tesla should not advertise electric usage X when it turns out my car consumes about 40% more than that starting in November.
You live in Colorado.
I wonder if people in Hawaii would have to be presented with different drain numbers than Colorado'ans…… as opposed to Iowan's as opposed to …….
You know what....I would LOVE for Teslas to become popular enough for range alerts to be reported during the major local network weather reports - like windchill.
paranoidroid
182
173
San Francisco
The low pressure warning at 41psi is really strange. I've run my car at 40psi for weeks and no warning. I bleed them down to 36psi cold at Buttonwillow for a day on the track and no warning either.
It does make me wonder how Tesla's warning algorithm works here.
StellarRat
1,490
1,337
Pacific
They apparently always treat the pressure as if the car is at sea level and don't do any adjustment for altitude. Every other car I have that has TPMS has sensors that agree with what a handheld gauge show, to within 1-2 PSI. Apparently this is a super technical challenge that is above Tesla's ability to fix... even though the car has a GPS and always pretty much knows what altitude it is at.
Or potentially they don't care because I guess that whiny high altitude people are not much of a priority compared to putting fart sounds in the cars.
So, it's reading higher up in the mountains than when you're in the low lands?
PhaseWhite
856
2,316
Minneapolis,MN
I didn't really "preheat the cabin". I turned climate control on for a whopping 10 minutes before starting my drive. The energy display for my drive showed usage of about 450 w/mile which is a ton and which does not include the usage that the car had when it was parked.
It's still returning higher MPG than any ICE car I could have chosen but it's a very very far cry from Tesla's advertised efficiency #s and cold weather owners will want to account for a number of things such as substantially higher electric usage during cold weather months, more brake usage since you won't get the "lifetime brake pads" that Elon cheekily tweets about when your car has limited regen for 1/2 of the year.... etc.
I still like my car but I don't love it. Between the buzzes and rattles that come and go, the super high vampire drain, the lackluster ability of the car to heat the cabin, the TPMS sensors that don't understand altitude changes.... this car is okay but I'm hoping that BMW knocks it out of the park when they release their I4 so I can get a car engineered by people that understand the challenges of living in a cold weather climate.
I think the range drop is a combination of vampire drain and a cold soaked battery. The vampire drain could be improved but the physics of lithium ion batteries will likely be the real limit to performance on the model 3 and future BMW competitors. Based on what we’ve seen from competitors recently in terms of efficiency and cold weather performance I wouldn’t get your hopes up.
voip-ninja
Give me some sugar baby
Mar 15, 2012
4,121
4,691
Colorado
Yes, it is quite well documented that Tesla does not adjust for higher elevations with their TPMS sensor readings and owners have apparently been complaining about it for years.
6,000 feet vs sea level works out to a 3 psi difference. Normally not enough to get upset about but when you're Tesla you are extra special and your tire pressure sensors go off when they are only 2-3 PSI below the door sticker recommended pressure.
https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=167
StellarRat
1,490
1,337
Pacific
I agree. There's no reason to believe that a BMW will be any better in cold weather. As far as I've read Tesla has the best batteries and battery management system in the industry.
Reactions: C141medic
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
I'm not going to argue that Tesla is ahead of the competition in the area of batteries & motors by at least 4-5 years and is continuing to innovate to maintain that lead.
In many other areas BMW offers a superior car owning experience, at least what I've observed in my first five months of Tesla ownership.
My comments re: BMW were not that they would be able to magically solve the issue with battery chemistry... but I can see them exceeding Tesla in many other areas, particularly vehicle service, fit/finish, cold weather experience (pretty much guaranteed they would not ship a car that had door seals freezing, charge ports freezing, inefficient resistive heater, etc.
Time will tell I suppose, I don't expect anyone to have anything competitive until at least late next year at the earliest.
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
It's not strange when you understand that Tesla is not adjusting for high altitudes.
StellarRat
1,490
1,337
Pacific
Then they are working correctly. When you are up high you're tires are acting like they have 3 psi more in them. This is exactly how airplanes work. When you're trying to take off at high altitude you need more ground speed because the air pressure is lower. The indicated air speed gauge will show how you what your effective speed is as far as what your wings and control surfaces are seeing. I'd say the Tesla TPMS sensors are more accurate than some other sensors that "cover up" the true situation.
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
This is absurd. Other cars I have owned with TPMS sensors adjust for the altitude difference, the Tesla does not. If the tires are inflated using a race gauge and set at 42 PSI at 6,000 feet the Tesla thinks the tires are at 39 PSI and throws an alarm. If I try to set the tires to the "comfort" inflation level (39PSI) that Elon Musk himself recommended for the Model 3 then the TPMS sensors will read 36PSI and will be in alarm.
I have never had disagreement between the TPMS sensors in my other cars and the gauges I use, so I have to assume that those manufacturers measure air pressure with the MAF or something else and adjust automatically. Those manufacturers also allow for a PSI variation of more than 2-3 PSI before setting off low pressure warnings in the cockpit.
Stop being a Tesla apologist on this issue, especially when you likely live at sea level and don't have to deal with it.
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
8,973
10,695
San Diego
For tire pressures, what matters is relative pressure (that's what a tire gauge measures). Unfortunately the Tesla sensors are not being corrected for local atmospheric pressure; they are displaying what is effectively absolute pressure. Apparently most ICE cars do this correction with the intake flow/volume sensors.
As already referenced earlier...
Model 3 TPMS sensors are junk
EDIT: I think this above-referenced thread title is misleading - there is nothing wrong with the sensors, it's just the way the data is reported & acted on by Tesla. END EDIT.
This is like Deflategate all over again. (Gauge pressure vs. absolute pressure was a thing there because people were trying to calculate how much the pressure changed for a given change in temperature to see whether the "GOAT" had done something nefarious.)
The good news is that I'm sure eventually Tesla will be able to software update this somehow. Shouldn't be that difficult...
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
For tire pressures, what matters for how inflated the tire is relative pressure (that's what a tire gauge measures). Unfortunately the Tesla sensors are not being corrected for local atmospheric pressure, they are displaying what is effectively absolute pressure. Apparently most ICE cars do this with the intake flow/volume sensors.
Elon tweeted yesterday that a picture of Mars was erotic enough that he felt he needed to nut, so somehow I don't think this is a priority. Honestly this problem has existed on Tesla cars since introduction, but the S and X must either have a wider margin before the low pressure warnings go on or they have a compliant enough suspension that owners don't mind over-inflating tires for it to be an issue for them.
And yes, you are correct, Tesla is displaying absolute pressure when all that matters from the perspective of tire inflation levels is the local atmospheric pressure.... also known as the actual measurable air pressure difference between the inside of the tire and the outside atmosphere.
Reactions: AlanSubie4Life
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
I didn't even know No Nut November was a thing until yesterday. Thanks Elon!
StellarRat
1,490
1,337
Pacific
I'm not being an "apologist". Science is science. Not the other way around. Should Tesla also not take outside temperature and tire heating into account? Those affect the pressure readings too. I'd want my tires to operate like they're supposed to at whatever altitude I filled them at. Fudging the numbers just to prevent owners from worrying is not good engineering. You have to draw the line somewhere.
Now, that said, I agree that maybe the low pressure alarm software should take altitude into account or at least note that the problem maybe altitude related, so it doesn't bug you for a minor pressure change.
  • Disagree
Reactions: voip-ninja
AlanSubie4Life
Oct 22, 2018
8,973
10,695
San Diego
I feel like you might not be understanding the core issue here - it's that the TPMS should be corrected such that they read gauge pressure because that is what matters. As an aside: temperature increases tire pressure due to the ideal gas law, but you have to use the absolute pressure to predict that change (add 14.7PSI to the gauge pressure at sea level, a few PSI less at 5k feet, and THEN use the ideal gas law, using ratio of degrees Kelvin). Temperature definitely affects gauge pressure and the absolute pressure in the tire, but the gauge pressure is still what matters because that is what determines how much the tire deforms.
Lets assume a perfectly calibrated tire pressure gauge.
The problem here is that in order for the OP to actually run the CORRECT gauge pressure (let's say the target is 42PSI, as the B-pillar recommends), in Denver, he must put in less air than he would need to at sea level to get his perfectly calibrated gauge to read 42PSI (because atmospheric is lower). The TPMS measures the pressure in the tire, and reads it as about 39.3PSI (it's presumably actually reading 54PSI (which is correct with Denver atmospheric pressure of 12PSI) , and subtracting 14.7 (NOT 12PSI), then displaying this result (39.3PSI)). This is because it is reading absolute pressure and not correcting for the atmospheric pressure.
This is the OP's (and @mongo 's) claim for how it works. I have not independently verified the behavior (I am at sea level), but it is certainly plausible.
StellarRat
1,490
1,337
Pacific
I thought he said that the pressure the TPMS was showing varied with altitude not that he couldn't put the right amount in at altitude. That's a different. In that case, I agree, it should compensate for altitude. However, the tires will read too high pressure when he moves to sea level and will actually be overinflated. There's really no easy way to fix this without cheating somehow. Unless the car stays at the same altitude always it will always vary.
voip-ninja
Mar 15, 2012
4,121
4,691
Colorado
Yet somehow other manufacturers have managed to fix this without "cheating somehow".
StellarRat
1,490
1,337
Pacific
No, they're just putting your mind at ease with the software. Your effective tire pressure IS changing with altitude. Just because it reads correctly by the software doesn't mean the tire is acting like it really has that much air in it. Anyway, I'm not going post anymore on this. It's not that big of deal to me.
