If they are saying it's a cable repair, I would go with that.
Tesla has refurbished main batteries or they may be able to repair yours if you need that service for less than $2,000. Low-cost battery repair is something people have been requesting from Tesla. It's not only better and less expensive than a new main battery, but better for the environment and will help their image overall. Also as stated previously, the packs are completely sealed normally and do have liquid battery cooling. You may want to ask them to check that the seal is good...I believe it should be since they use a high-quality process to seal the main battery that will help protect it from water or debris intrusion.
I'm also interested in what happened with Jesskidog's car. Hopefully everything is good now.
So this is the estimate $3234.00
Correction: Pyrotechnic Battery Disconnect (Remove & Replace)
Price Adjustment
40.00 0.00
Price Adjustment
55.00 0.00
340.00 0.00 165.00 0.00
Subtotal
40.00
Subtotal
55.00
340.00 165.00
Parts Replaced or Added
Part Quantity
PRYOTECHNIC 1.00 BATTERY
DISCONNET(1004635-
00-A)
Unit Price
55.00
340.00 165.00
FIELD CTR KIT W/O FUSE PACK 1.0 1.5(1084515-00-E)
ASY, RAPIDMATE PLATE, HVBAT,MDLS(1015753- 00-C)
FIELD KIT PYRO FUSE
1.00 1.00
1.00
340.00
340.00 0.00
340.00
2,984.00
1 of 4
PACK 1.0 1.5(1089619- 00-D)
Correction: Thermal System Test
Correction: Vehicle Electrical Isolation Procedure
Price
20.00
Price
100.00
Price
240.00
Price
24.00
Parts Subtotal 900.00 Adjustment Subtotal
0.00 20.00
Adjustment Subtotal
0.00 100.00
Adjustment Subtotal
0.00 240.00
Adjustment Subtotal
0.00 24.00
Parts Subtotal 24.00
Correction: HV Battery (Remove & Install) Parts Replaced or Added
Part
BATTERY BOLTS, SERVICE REPAIR KIT, SX(1138547-00-A)
Quantity
1.00
Unit Price
24.00
Correction: HV Rapid Mate - Vehicle Side (Remove & Replace)
Price Adjustment
820.00 0.00
Price Adjustment
840.00 0.00
Subtotal
820.00
Subtotal
840.00
Parts Replaced or Added Part
HIGH VOLTAGE BATTERY TO REAR HIGH VOLTAGE JUNCTION BOX HARNESS ASSEMBLY(1004875- 00-F)
Total Parts Amount
Total Labor Amount 1,220.00
Quantity
1.00
Unit Price
840.00
1,764.00
Parts Subtotal 840.00
Pay Type: Customer Pay
Because I drove through a puddle of water. Something tells me I had to be more than driving through a puddle. Ideas?
