Alignment same for 85D/85/P85?
Discussion in 'Model S: Driving Dynamics' started by vvanders, Feb 6, 2016.
  1. vvanders
    vvanders Member
    Portland, Or
    Just got back from yearly service for our 85D and they did alignment(awesome!) but noticed at the top of the alignment page that it's for "Model S: Single Motor Rear Wheel Drive : Air Suspension(SU01) / Performance Plus (SU02/SUPP)". Do they use the same alignment specs for all Dual Motor and Single Motor models?
  2. sorka
    sorka Well-Known Member
    Merced, CA
    Anyone? I searched myself and could not find anything. Usually AWD variants will have different toe adjustments because the thrust angle changes as the car is pulled partly from the front vs only the rear.
  3. mmccord
    mmccord Member
    Pine Bush, NY
    I had one done in November and it just says:
    "Four Wheel Alignment - Check and Adjust (with Air Suspension)
    Performed four wheel alignment with ride height calibration."
    They charged me over $500 for it.
  4. Polyport
    Polyport Member
    SLC, UT
    I just had my one-year service done and the alignment was $150 (the service center called me and confirmed the cost with me before they performed the alignment.) However, on the bill it showed up as $550, since they didn't break out the cost of the service ($400) separately. I would venture a guess your over $500 cost included the cost of your service visit?
  5. sorka
    Merced, CA
    Geez, and I thought $189 for lifetime alignment was a lot.
    Can you post your alignment sheet for your D car as it will have the specs in it.
  6. Polyport
    Polyport Member
    SLC, UT
    I didn't get a separate alignment sheet. Only the service invoice. Didn't know I had the option of getting a sheet that showed details. I've attached the part of the invoice where it lists the alignment work.
  7. sorka
    Merced, CA
    By law, even without you requesting it, they are supposed to provide the alignment sheet showing before and after.
  8. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    Also, your alignment was for coil suspension. Air suspension may have different parameters even with the same model.
  9. mmccord
    mmccord Member
    Pine Bush, NY
    If they did a one year service they didn't tell me. Also they verbally quoted me 450 for the alignment. The other $100 was for mounting/balancing my snow tires.
